Tip & How-To about Maytag M6Q10F2A Air Conditioner
Will Not Shut Off
My air conditioner will not stop making noise, even when it is shut off. I turned it off, and it makes the same noiseas if it was on, but no air comes out until I turn it on. Als, I have to unplug it inorderto stop the noise. Thanks.
J
Maytag M6Q10F2A Air Conditioner Logo
my rheem 90 plus, has a humming noise any time the power switch is turned on even with thermosat unplugged. i shut the switch off and it stops. do i have a short some where?
Hello, typically a humming noise comes from the transformer located in the blower section of the Furnace. Sometimes it is caused by the transformer being loose, and others it can be a sign of the transformer going bad. i would make sure that it is secure first and see if that helps.
Oct 28, 2011 | Heating & Cooling
2000 Chevy Cavalier making a noise when air is shut off
This problem sounds like the aircompressor pully, the bearing is shot.
With the engine running and the air conditioner off there is a grinding noise, look at the compressor pully, does it wobble? Then turn on the air conditioner and the noise stops, look at the compressor pully again, the wobble stops? If so that's the problem.
Jun 27, 2010 | 1996 Chevrolet Cavalier
917 people viewed this tip
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
