Tip & How-To about Bugaboo Cameleon Jogger
Why not to buy the Bugaboo wheelie board for your Bugaboo
Because the Mutsy one is better, safer and cheaper. Mutsy make a wheelie board that comes with an rubber adapter for the all the Bugaboo's except the Bee. The Mutsy is made from metal vs Bugaboo's Plastic. The Mutsy has simply finger operated locks to take on and off vs having to virtually turn the Bugaboo upside down to get it off or on. The Mutsy has an adjustable length and a flat deck with no protrusions vs the Bugaboos fixed length and a massive protrusion in the deck. The Mutsy wheel is directly under the child putting less weight on the stroller vs the Bugaboo's wheel being behind the child putting half their weight on the stroller. And the clincher! It's half the price! Go try one out.
Bugaboo Cameleon Jogger Logo
I'm looking for instructions to attach the buggyboard to a bugaboo bee +
I'm not sure the board fits the Bee+ Check with Bugaboo Customer Service If you can find a shop with Mutsy's try their board. It's a far better design and we use one on our Cameleon it has a set of rubber adaptors for the Chameleon. Frog & Gecko but the Bee has a higher and not so wide back bar so check first.
Aug 24, 2011 | Bugaboo Bee Umbrella Stroller
I am sorry for my last posting; I was unfamiliar with the procedure. My problem is as follows: I have trouble folding the chassis of my Mutsy 4rider. I have read the manual which states I am supposed to pull the side lever and push the switch button simultaneously. I have watched some videos on YouTube and know which levers should theoretically make it work. However, it doesn't. I have been told that other people have had similar problems and that there is supposedly a special "technique" beyond what the manual states. Which is the technique? Or is it possibly broken? If there was a video available, I would also appreciate it. Thank you for your support!
It is tricky and if there's a knack to it I don't quite know how to put it into words. If it's new take it back to the shop and have them try it. It may be faulty we had a Musty wheely board that would not adjust and it had to be replaced by Mutsy. If you bought it second hand ask the seller how they did it. I'm a great fan for silicon spray it's a lubricant that won't stain fabrics. Buy a can at any hardware store, get one that has the little straw so you can get it into tight places without to much over spray. Last idea, take it to party or any other group gathering and have a competition to fold & open it. It should be fun watching all the men struggling with it. 8-)
Dec 01, 2010 | Mutsy 4 Rider Light - Navy Blue Standard...
cannot attach wheeled board to Bugaboo Chamelean with Bassinet
In previous posts I've said the Bugaboo gets an A for design, The wheeled board gets a B-. Your problem is you're trying to fit it with all four wheels still on the ground. Put to on it's side and you can the rotate the board further around to fit the clips. Go here to get Bugaboo's instructions For those yet to buy a wheeled board click on my name or picture and click on Tips. There is a better alternative to the Bugaboo board.
Nov 27, 2010 | Bugaboo Cameleon Jogger
i need a new clip for my bugaboo buggyboard
Your only chance is to try your luck with Bugaboo customer service. If it's less then 2 years old and you have purchase documentation they are helpful. Out side of that..... not so helpful. If you you don't need to fold your Bugaboo down a large hose clip could clamp it on. If you need to replace the whole board check out my tips on the Mutsy board vs the Bugaboo. Just click on my name then tips.
Nov 24, 2010 | Baby Gear
Spare Parts for Bugaboo Wheeled Board
For Bugaboo spare parts, the best way is to contact Bugaboo direct (www.bugaboo.com) or a local Bugaboo stockist who should be able to order in the spare part for you.
Sep 15, 2009 | Baby Gear
861 people viewed this tip
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
