Tip & How-To about Office Equipment & Supplies
Xerox machine ir 3320, error 602-003 and 602-004\r\n
The E 602- 003 is due to hard disk system error but you can scan it ;run check disk its can fix that problem. try this, hold on 1 and 9 (from the machine key board) then switch on the copier; then wait around 1 hour all screen will be white then the copier will display download mode. then switch off and put on the copier.
How do I fix currupt data
I believe you mean "corrupt data". When we have message corrupt data means that something wrongs with hard disk. You can try correct problem running full disk check.
Check your hard disk for errors
You can help solve some computer problems and improve the performance of your computer by verifying that your hard disk has no errors .
Open Computer by clicking the button " Start " and then click Computer.
Right-click the hard drive you want to check, and then click Properties.
Click the Tools tab , and then , under Error-checking , click Check . Administrator permission required If you are prompted for an administrator password or confirmation , type the password or provide confirmation .
To automatically fix problems with files and folders that the scan detects , select Automatically fix file system errors . Otherwise , the disk check will report problems but not solve .
To run a full disk check , select Scan for and attempt recovery of bad sectors . This scan attempts to find and repair physical errors on the same hard disk and may need more time to complete .
To check for errors in both files and for physical errors , select both check boxes AutoCorrect file system errors and Scan for and attempt recovery of bad sectors .
Click the Start button .
Depending on the size of your hard disk , this process may take several minutes . For best results, do not use your computer for other tasks while it lasts error checking .
note
If you select the Automatically fix file system errors for a disk that currently in use (for example , the partition that contains Windows), you will be prompted to reschedule the disk check for the next time you restart your computer your .
Jan 29, 2014 | Toshiba Computers & Internet
Hi,my laptop become so slow and its keep freezing
Head over to download.com and do a search for Ccleaner. Once you download and install it, run the cleaner and registry fixer. Registry errors are a common cause for a computer slowing down. If you are running Windows XP, a good idea would be to change the size of paging file which will increase performance.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/sysdm_advancd_perform_change_vmpagefile.mspx?mfr=true
May 09, 2011 | Fujitsu AMILO PC Laptops
The file or directory is corrupted and unreadable
The file or folder could get corrupted due to improper turning off the PC like abrupt power cut
without an UPS backup and various other reasons.Unfortunately there is no guaranteed way to fix the
corrupted file/folder,but there are few things you could try that fixes the issue sometimes.
1) You can ask windows to check for errors and fix them.This may fixe the corrupted files or folders in some cases.Follow the steps below to run the error checking process.
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer? Click Yes to schedule the disk check, and then restart your computer to start the disk check.
Like I said there is no guarantee this would fix the issue but its worth the try.The only way to keep the folders or files safe is to make backup copies on another hard drive or CD/DVD.Do let me know if it helped.
Thanks for using Fixya!
Dec 11, 2010 | Seagate (ST980811AS) 80 GB IDE Hard Drive
LAPTOP SLOW
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Nov 06, 2010 | Acer Aspire 4720 Notebook
i have a xerox machine ir 3320 i have facing a error 602-003 and 602-004\r\n and printing are coming zigzag type
try this,
then wait arround 1 hour all sceer will be white then the copier will display download mode.
Oct 31, 2010 | Canon Office Equipment & Supplies
175 people viewed this tip
k24674
