Tip & How-To about Computers & Internet
Problem with the Microsoft Windows Live Messanger
1. Run "sfc /scannow" and restart the computer; 2. Uninstall WLM9 with Zap Messenger; http://messengergeek.spaces.live.com/blo... http://www.softpedia.com/progDownload/Za... 3. Donwload and install Windows Installer Cleanup Utility for vista/windows 7;Windows Installer CleanUp Utility 1.0 http://support.microsoft.com/kb/290301/e... 4. Run the utility, select all items concerning Windows Live and remove them;
5. Run WLM9 installer again. Windows live Messenger 2009http://download.live.com/?sku=messenger
Computers & Internet Logo
error code Ox80092003 on vista pc
Run System File Checker (SFC) to check if Windows Vista system files are corrupted.
1. Click Start, type "cmd" (without the quote) in the Start Search bar, right-click cmd.exe and click run as administrator.
2. Input the following commands and press Enter after each line.
sfc /scannow
Note: There is a SPACE between "SFC" and "/Scannow". This command will take several minutes to complete.
Restart the computer.
Sep 11, 2013 | Microsoft VISTA Computers & Internet
mi problems no cd
Install it another computer which is running well.If your cd run well in that computer ,change the USB cable .If the cd can not run in another pc you think, you have lost data.Because that cd can't run any more.
If the problem is same.
follow the step
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb hub ,one after one .
After UN install all the usb, restart your PC .
If the problem , is same as before ,
Insert your OS in the cd tray > press Win key + R>type sfc /scannow (please take a space between sfc and front slash)>hit enter .Again you will restart the PC.
If the problem is same please change the Hard disk.
Hope it will help you
Jan 20, 2011 | ASUS P5KPL-AM SE Motherboard
hello, sir/madam, i would like to know how to solve 8007007e? Thanks.
2. Uninstall WLM9 with ZapMessenger;
Nov 01, 2010 | Microsoft Windows Live Messanger
my IE 8 will not open any web sites
Is your Network Connections working properly?
If your networking adapters are functioning OK, try this,
Open IE
Tools tab > Internet Options > restore Adanced Settings and Reset Internet Explorer settings.
Restart IE.
Other options are:
1) Uninstall the Network adapter
Open Device Manager > Expand Network Adapter > Right Click on your internet network adapter and Uninstall
Reboot
If it doesn't work, try it again and then reinstall the driver. You may have to get the new driver from the device website.
2) Winsock and Tcp/Ip Fix
Start > Run > Type CMD > Type the following:
Reset TCP/IP stack to installation defaults,
type: netsh int ip reset reset.log and Press Enter
Reset WINSOCK entries to installation defaults,
type: netsh winsock reset catalog and Press Enter
3) Run sfc /scannow (This will restore your system files back to original state)
Insert your XP disc
sfc /scannow
Hope it helps.
Jul 15, 2010 | Microsoft Internet Explorer 8
copy paste
1. Type http://djlizard.net/software/Dial-a-fix-v0.60.0.24.zip in internet explorer address bar and hit enter and save the file on your desktop. after that try to open it and run dial-a-fix select all option then close it and restart the computer.
2. Try this:-- Internet Explorer, Tools, Options, Security tab, "Custom Level" button, Misc: "allow cut and paste for files", dot the "allow"
3. Try to run sfc /scannow and restart the computer ( Click on Start> Run> Type sfc /scannow )
remember inbetween the scanning you need to insert the windows XP sp2 Disk.
Nov 22, 2008 | Computers & Internet
185 people viewed this tip
David Payne
David Payne
