Tip & How-To about Computers & Internet
How to Troubleshoot a Toshiba Power
Click on the Windows "Start" button.Click on "Computer" or "My Computer Double-click on the primary hard drive. This is usually labeled as drive "C. Double-click on the folder labeled "Windows. Double-click on the folder labeled "System32.Right-click on the program labeled "TPSMain.exe." This is the executable program file for your Toshiba Power Saver software. "Properties.Click on the "Previous Versions" tab at the top of the window. Scroll the list of previous versions until you notice an earlier date and time when Toshiba Power Saver software worked properly. Click to highlight this listing.Click"Restore." Your computer will automatically restore your software to its previous state, before the software error began. If this does not fix the problem, your software may be corrupted by malware, and additional troubleshooting is required.Repeat Steps 1 through 6 Clickon "Scan with Microsoft Security Essentials" from the list of options.According to Microsoft, Microsoft Security Essentials is available for free to all Windows XP, Vista and Windows 7 users. Toshiba computers all use the Windows Operating System, so you should have access to Security Essentials. If you do not see the scan option, your computer probably did not come with Security Essentials pre-installed. You can download it for free at Microsoft's website. Wait while Windows automatically scans TPSMain.exe for possible malware. The s can can take several minutes. If the TPSMain.exe file is infected with malware, it can hinder performance. Click "Remove" if any malware is found.please make comment on this product by saying how helpful it is.
Computers & Internet Logo
how i make the laptop open to see memory cards
Use the windows start button and scroll across to computer. double click on that and you should see what drives on your laptop. C-drive is usually the main hard drive with all your windows operating system files.
Oct 01, 2014 | Acer Computers & Internet
pc does not recognize external drive
External hard drives are plug-and-play devices used to store music, video and data files.
Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
b>
Jan 07, 2013 | SmartDisk Verbatim 96867 2 TB External...
just bought a used sony vaio pcg 955a what size ram and hard drive would be in it
Start Windows.
Click Start
Click with the SECOND (usually the RIGHT) mouse button on "My Computer".
Click Properties.
Windows XP/Vista/7 will tell you the CPU-speed and the amount of RAM.
Switch from the 'General' tab to the 'Hardware' tab, and click "Device Manager".
Select the disk-drive, and double-click it to show the size of the disk-drive.
Aug 18, 2011 | Computers & Internet
how do I drag files to my external drive
Assuming you are using Windows, click the start button then click computer, double click the drive. Then click the start button again and click computer and then find the folder you want to copy from. You should now have 2 windows open, one for the hard drive and the other with the files you want to copy. Just drag the files from one window to the other.
Jan 17, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
My computer needs a clean out.
Perform the steps given below to increase you system performance.
Uninstall all unwanted software.
To uninstall software:
Click on Start -> Settings -> Control Panel -> Add/Remove Programs
Select the software (one at the time) from the list and click on Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temporary folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag. You should defrag every hard disk on your system. This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Next :-) please vote if this help you
Nov 29, 2008 | Computers & Internet
143 people viewed this tip
David Payne
David Payne
