Tip & How-To about Lenovo ThinkVision L1951p LCD display TFT 19" Monitor
Removing stand arm
Hi all
Thought I'd share this.Lenovo discontinued the excellent L1940P, which had a stand that allowed pivoting as well as tilting and height adjustment.
So I've bought a L1951P and mounted it onto a stand from Ergotron.
Problem: the Lenovo comes with a hinged arm extending below the bottom of the screen. The Lenovo-supplied stand fits on the end of this arm. How to remove this arm so that it doesn't get in the way of a VESA mounting?
Well, I called Lenovo tech support, and they know nothing beyond what's in the manual that I've read. They claim that this arm is an integral part of the case and can't be removed. Wrong. I really love it when the people I talk to in tech support are actually people who know more about their product than I do...
At the top of the arm is a cylindrical plastic cowling covering the arm hinge. Put the monitor down flat on its front (on a cloth is a good idea to prevent scratches), tilt the arm upwards away from the case, and use a pen-light to look into the gap under the arm. You'll see a little tab on each side, inside, which is part of the cowling and locks the cowling onto the main case.
Use a small flat-head screwdriver to gently push this tab outwards - if you can apply a little pressure away from the case (i.e. upwards, as the case is downwards at this point) as well, you'll see the cylindrical cowling come away from the case on that side. Repeat on the other side. Remove the cowling, and you can access the 3 bolts that hold the arm onto the case. Done!
Lenovo ThinkVision L1951p  LCD display  TFT  19" Monitor Logo
vibrates and beater hits bottom of bowl
Try adjusting the height of the head by turning screw #36 counterclockwise a turn or so. This will raise the mixing head so the beaters no longer hit the bottom of the bowl. Refer to parts list:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
If the pivot pin #18 is not centered and secured then center the pin and turn the mixer on its side to tighten screw #31 from underneath the mixer to secure the pivot pin.
Apr 17, 2010 | KitchenAid KSM150PS Artisan Series Stand...
mixer blade is chipping
If it is a tilt head mixer then adjust the screw which can be seen by tipping the head back and looking into the pivot point. Turn the screw CCW to raise the head and prevent the paddle from hitting the bottom of the bowl.
If it is a lift bowl mixer there is an adjusting screw on the frame of the stand behind the bowl holder mechanism. It rurns a cam which adjusts the height of the mixer.
See pg. 13 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707917.pdf
clockwise to lower the head and counterclockwise to raise the head for more clearance for the beaters.
Sanyo DP19649 - how od I unlock the stand pivot so
Sorry you can not pivot the table stand on the tv. If it is a wall mount can you give model # and make. Or you can look in back of the tv and you should see the pivot point in the center of the bracket that holds it to the wall.
Dec 27, 2009 | Sanyo Televison & Video
Stand jumps
The height of the beater is easy to adjust on the tilt-head model.  Tilt the head back, and look into the pivot from the front of the mixer.  You should see a screw on the hinge.  With a flat blade screwdriver, rotate this screw half a turn counter-clockwise to raise the beater height.  Lower the head and check that the beater does not touch the bowl.  Repeat until the adjustment is satisfactory.  To lower the beater closer to the bowl, turn the screw clockwise instead.
Jan 12, 2009 | KitchenAid K45SS Classic Stand Mixer
HP f1905e tilt and Height adjustment
I figured it out! Just takes a phillips screwdriver and a 5/16" open end wrench to tighten up some nuts inside the plastic housing. The plastic housing doesn't come off with the screws, but has to be slightly pryed up to release the little plastic catches. Be careful though, you don't want to break the plastic tabs. It's ok to break maybe 1 because there are several to take up the slack. At first I thought it was the nuts that are 1/2" (there are two that are close to 2 springs. But that was just for the tilt forward and backward. Actually there are 4 nuts (5/16") that need to be tightened. Don't over tighten or it will not tilt at all. I took photos of the disassembled base. If you have skype, then skype me at "golfbob" chino hills, and I can send the pics or talk you through it. Good luck.
Jan 11, 2008 | HP f1905 19" Flat Panel LCD Monitor
6,101 people viewed this tip
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
