Tip & How-To about Garden
Winterizing your Pressure Washer
Once again it's that time of year to get your pressure washer prepared for the cold months ahead. Proper winterization will protect your pump from the freezing of excess water in the pump over the winter. There are many ways to winterize your pump; we like to classify it as the good, better and best.
Good: (Gasoline powered) Leaving your machine in the off position with the high pressure hose disconnected pull the recoil rope 4 to 5 times or until you don't see any more water coming out of the high pressure end of the pump. (Electric powered) Disconnect your high pressure hose, turn the machine on for 5 to 10 seconds or until you don't see any more water coming from the high pressure end of the pump.
Better: If you have a air compressor around the house, hook the air line to the garden hose end of the pump and blow the water out until you don't see any more water coming out of the high pressure end of the pump.
Best: Purchase Karcher's Pump Guard, follow the simple directions that come with the product. This product is specially formulated to keep your pump from freezing, corrosion, premature wear, adds lubricant to the valves and seals to prevent sticking in the spring. You can usually get 2 or 3 uses from one bottle of Karcher's Pump Guard.
Visit this link to read more
Garden Logo
What weight oil does the honda 5.5 engine require?
Your Honda 5.5 hp engine specifically calls for SAE 5W30 engine oil. Use a good quality oil in the engine, and change it every 50 hours of run time. The pump will take 30weight non-detergent oil.
Using non-detergent oil in the engine will probably void your warranty, and will certainly shorten the life of the engine. Non-detergent oils have not been recommend by engine manufacturers in nearly 20 years.
Oil is cheap, go ahead and spend $4 - 5 on a quart of high quality oil. Your engine uses about 20 ounces per change.
Oct 01, 2010 | Honda 2500 PSI Gas Pressure Washer
Will not draw soap solution
Follow the pipe back to the pump and you will find a ball and spring inside.This could well be stuck closed if it has been stored for some time. Oil this part and it should draw soap again.
Jun 23, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
I have a troy built 2450 pressure washer. The engine runs fine but I have no pressure out of the hose. Does the pump require that you put oil in it?
Do you live where it is cold in the winter? And did you winterize the pump this past winter if it is cold? They need to be winterized or pump damage can occur.
May 09, 2010 | Garden
I have a 3000 psi karcher pressure washer with honda engine, the problem is for a while the pressure would kick in and out, now only water hose pressure, the water supply is fine, what is the problem
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Sep 15, 2009 | Karcher G3025OH Pressure Washer
losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
2,601 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
