Tip & How-To about Computers & Internet
How to Unlock a Zip Password
ZIP files are files in archive format. In this format, files are compressed to save storage space. ZIP files can be password protected to ensure privacy. It is possible to bypass or unlock ZIP file password using third-party software.
  • Download and install a password recovery program for ZIP files on your computer, such as Zipunlock, Advanced ZIP password recovery, or ZIP Password recovery 5.0.
  • 2Start the program by double clicking on the icon.
  • 3Open the password protected file.
  • 4Click on "Start" to unlock the password protected file.
    ZIP Password recovery 5.0 is an easy and effective utility, designed to recover lost or forgotten passwords for ZIP/PKZip/WinZip archives. The program supports the customizable brute-force attack, effectively optimized for speed dictionary-based attack, and very fast and effective known-plaintext attack. Supports strong WinZip encryption (AES). Multilangual user interface. http://www.recoverlostpassword.com/products/zippasswordrecovery.html
  • Posted by on
    Computers & Internet Logo
    How to Zip and Unzip Files with Peazip?
    Follow this steps.
    1.PeaZip is a freeware cross-platform archive
    manager that provides a single GUI for Open
    Source technologies ( 7-Zip , FreeArc, PAQ,
    UPX. ..) on Windows, Linux, and BSD. The file
    manager allows both to select files and
    folders to be archived as Zip files (or other
    formats), and to select archives to be
    unzipped. Alternatively, file selection can be
    performed with PeaZip system's context
    menu entries (not featured in PeaZip Portable
    version) or simply dragging and dropping files
    from / to the program.
    2.Archive creation can be started dragging files
    on the application, or with "Add" button in
    program's tool bar. The archive creation
    interface prompts by default creation of a Zip
    file, but the file format can be customized, as
    well as compression ratio (from faster to
    better) and other miscellaneous options,
    including encryption. PeaZip relies on
    optimized Deflate algorithm for compressing
    in Zip format, that usually compress 5-10%
    better than standard Deflate but keeping
    compatibility with other Zip utilities. 7Z
    format gives better compression ratio, but is
    slower than Zip. As quite unique feature for
    archive management software, PeaZip
    supports two factor authentication (password
    plus key file), random password generation,
    and features an integrated encrypted
    password manager. "Advanced" tab features
    more fine-grained options, "Console" tab
    transform the task in a command line i.e. for
    use in scripts or for study purpose,
    "Schedule" tab allows to transform the
    interactive task in a scheduled one.
    3.Archive extraction can be started from system
    context menu, or dragging compressed files
    on the application, or with "Extract" button in
    program's tool bar. It can handle multiple
    archives even of mixed types at once, or
    selective extraction of content from a single
    archive. Over 170 types of archives are
    supported: classic ZIP files and its variants,
    new WinZip's ZIPX file format, RAR files, old
    ACE archives, Microsoft's CAB and WIM files,
    Apple's DMG packages, ISO and UDF disk
    images, and many more.
    Oct 19, 2016 | Computers & Internet
    How to Use WinRAR?
    The WinRAR application will compress the files and save in the same folder or location as the original files. The WinRAR program can also extract compressed files with a RAR or ZIP format. Select the files that require extraction using the pointer. Right click on the selected file to display a drop down menu.
    Materials Needed:- PC
    - winrar archiver program
    - file to compress
    - compressed files
    Step 1
    Ensure that the computer you are going to use for compressing files has WinRAR program installed before proceeding with the compression of file.
    Step 2
    Select all the files to you want to compress by using the mouse and the CTRL button or the SHIFT button. The CTRL button is for selecting several files in the same folder or location. The SHIFT button is for selecting blocks of files.
    Step 3
    Right click on the selected files to display a drop down menu. Select the 'Add to Archive' option from the drop down list. This will display a WinRAR window menu.
    Step 4
    Input a name for the compressed files in the Archive name section in the General tab. Ensure that the name is not similar to any other compressed files in the save location.
    Step 5
    Select the file format of the compressed file after the deciding on the name. File formats can either be RAR or ZIP. There are also other options such as deleting of the original file after the compression, putting authenticity verifications, and putting a recovery record.
    Step 6
    Click the 'OK' button after completing all the required fields in the menu. The WinRAR application will compress the files and save in the same folder or location as the original files.
    Step 7
    Step 8
    Right click on the selected file to display a drop down menu. Select the 'Extract files' option from the menu. This will display a window from the WinRAR program.
    Step 9
    Specify where the extracted files will be located in the 'Destination path' option of the General tab. Do not replace the destination path if the extracted files will also be placed in the same location as the compressed file.
    Step 10
    Click the 'OK' button after filling the required fields in the window. This will start the extraction process of the RAR or ZIP file.
    E-mailing photos
    JPEG format storage is ideal for posting your photos to the Internet and for e-mailing them to friends. (It’s also useful for archiving when you've finished editing them and need to save storage space.) The compressed images still look good on-screen and contain a relatively large amount of information in the shrunken file. JPEG storage is great for maximizing space but not for maintaining image quality. If you want to get smaller files for archiving, use minimal JPEG compression (high quality/low compression). The ideal compression is lossless, which means there's no discernible drop in image quality even though the file size has decreased.
    Sep 08, 2005 | HP Photosmart 120 Digital Camera
    543 people viewed this tip
    David Payne
    David Payne
