Tip & How-To about Cell Phones
Rim Blackberry - Change Line1: Unknown Number to your Name and Number
When you press the call button you will see line1:unknown. This can be changed to your name:number, to do this
  1. ->Options
  2. ->Advance Options
  3. ->Sim Card
  4. Scroll down
  5. Phone Numbers
  6. Click Blackberry Button
  7. Click Edit Sim Phone Number
  8. Then Enter the relevant info
  9. Then click the trackball or trackpad
  10. The information will now appear
Cell Phones Logo
Hi I have a Nec DT300 at work. I am on a new desk. Do you know how I can change the name which is on the display.
If you have the Admin password then follow this procedure:
For a DT330 (24-Button with 4 line LCD)
Do not lift the handset and press the Speaker button
Enter #*#*
Enter the 4 digit admin password and press the Transfer button
The phone will now display 'Program Mode'
Select Base from the four options using the associated softkey
Enter 15 and press the select softkey 2 times
The Extension Number and Ext Name will be displayed
Find the Extension Number you want to change the Extension Name for using the + and - softkeys
Press the Mic button to go to the Ext Name line
Enter the New Name using the number dial keypad.
If you make an error the Recall button will delete a character to the left and the Hold button will delete all characters to the right of the cursor.
Press the Transfer button to accept the new name.
Press the Answer button 4 times or until 'Program Mode' is displayed.
Press the Speaker button.
The system will save the changes and return the display to normal.
Feb 14, 2015 | NEC Lands Phones
set time on MSP74810W
Instructions for setting an MSP74810W watch.
Press the "Mode." button three times (the "Mode" button is the one next to the lower left of the dial when facing it).The first time you press you'll see the ST, or stop watch function, the second time you'll see the AL, or alarm function, the third time you'll be back to the time of day function but the seconds will be flashing.
Change the flashing seconds digits to read 00 by pressing the "Start" button (the "Start" is the button next to the upper right of the dial when facing it).
-To advance from the flashing seconds' reading to the hour of the day's digit/digits you press the "Reset" button at the lower right of the dial,
-To advance from the flashing hour digit/digits to the minutes digit/digits you again press the "Reset" button,
-To advance from the flashing minutes digit/digits to the month's digit/digits you again press the "Reset" button,
-To advance from the flashing month's digit/digits
to the day of the month's digit/digits you press "Reset,"
To advance from the flashing day of the month's digit/digits to the day of the week's abbreviation you again press "Reset,"
-To advance from the flashing name of the week's abbreviation back to the seconds' of the minute you again press "Reset," and from there you can go through the cycle again.
While the hour of the day with its A[M] or P[M] designation, the minutes of the hour, the month of the year's number, the day of the month's number, or the abbreviation of the day of the week's name is flashing press the "Start" button once, repeatedly, or hold it down to advance the number or letters to their correct designations.
Once all designations are correct push "Mode" so that none of the numbers or letters are flashing. Your watch is now set.
Apr 01, 2014 | Watches
can't change name on phone? the screen that pops up reads "terminals&sets" and I "set" to change a certain line. Show set is displayed. I type in the number that the name needs to be changed and the only options are to "copy" or "find". No Change is anywhere!
It sounds like your in the right area, you just need to go a little farther into that sets programming.
when you enter in the persons extension number press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name.
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
Dec 22, 2010 | NorStar M7324 Telephone
when making a call my number shows unknown on other phones.
To solve this problem click on call log,click button left of roller ball,scroll down to options and select.click general options, choose the option to be changed,click left of roller ball and change.
Dec 20, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
need to change name and number
Press the MENU button and press 7, then 2 on the numbers keypad. You can then use the keypad to change the fax header. Press the keypad numbers corresponding to the letters you need. It will cycle through lower case first, then upper case. Press the RIGHT arrow button to advance one space between letters.
Jul 18, 2008 | HP 920 Plain Paper Fax
2,335 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
