Tip & How-To about Office Equipment & Supplies
How to Refill the Epson R340's Ink Cartridge
Instructional steps
Things You'll Need:
  • Syringes
  • Refill ink
  • 1/16 inch thumb screw
  • Paper towels
  1. Place the cartridge on a flat surface over some paper towels to soak up any spilled ink.
  2. Drill a hole directly above the "H" in the word "Push" on the top label.
  3. Drill a hole above the the first hole so air can escape while you are filling the cartridge.
  4. Fill a syringe with the correct color and amount of refill ink. The black cartridge holds 25 ml of ink. Color cartridges hold 10 ml of ink.
  5. Insert the needle of the syringe into the first drilled hole. Slowly inject the ink into the cartridge.
  6. Replace the cartridge into the Epson R340. Allow it to rest for 24 hours so the ink can absorb into the sponge inside the cartridge.please rate this post by saying how helpful it is to you
how to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
I have the ink, syringes, ect to refill my lexmark x2500. Now how do I do this?
you will need more than just you also will need to purchase a cartridge reset tool to reset and calibrate the cartridges after refill
Jan 14, 2010 | Lexmark X2500 All-In-One Printer
How To Refill?
Harry, you can use every DYE ink for brother printers. DO NOT use pigmented ink due to clogged filters inside the printhead!!!! The carts for mfc210 are filled with 20ml for BK and 11ml for C/Y/M. I use to refill 20ml only ink for bk and 10ml ink + 1ml printhead cleaner for C/Y/M. See here how to do that (LC900 refill): http://www.hstt.net/refill-faq/brother.html#LC-900 Refillen (Simply drill a hole into the brother brandname and leave it open!) I use a 20ml syringe and 3 12(10+2)ml syringes from the drugstore (ask your doc! It may be cheaper ;-)
Sep 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
126 people viewed this tip
jasbo
jasbo
