Tip & How-To about Audio Players & Recorders
Cheap Homebuilt Multimedia PC With HDMI
Yes you CAN!
I built one of these myself and it took about 3 hours including the installation of the Operating System.
The key component however is this.
As you can see this is a Remote control which uses a USB receiver. There are many models available and I got mine from Amazon.com for $8. No drivers are required for this remote and several of the buttons are programmable.
You don't program them from the remote though. You create a shortcut to whatever it is you need to open on your desktop. That shortcut is then edited to open with a command set already programmed into the button. Genius huh? There is also a mouse built into this remote that functions pretty nicely and includes the right and left buttons.
My rig was built with a Dell GX280 $75
Which includes a low power ATI X1300 PCI X-Press video card with DVI out that I bought on Ebay for $13.
This card is one of the few PCI X-Press models that won't kill your power supply(No Fan). My GX280, as you can see from the photo is a SFF (Small Form Factor) PC, and as such has a very small power supply. This means that I cant use a power hungry card, while at the same time I need a card that will perform well in 3-D applications as well as streaming video from such sites as Hulu, Veoh, Youtube, TV.Com, and Fancast.net to name a few.
The real magic, however is that this card is capable of delivering 720i/p and 1080i/p resolutions to my HD-TV.
Yes thats my model.Close enough anyway.
One gig of ram will work, but 2 gigs is better for streaming. Since this PC is so small (About Phone Book Size) it fits in any entertainment center with ease. You can also add a TV tuner, but this is a waste of time since most HD-TV sets include ATSC/QAM/NTSC in their own tuner. If you want to record Live Video, pause live TV etc though, a PC-TV tuner will be the way to go. This essentially makes the PC a Tivo and DVR since you can digitally record HD Video, as well as schedule your recordings. At this point you may be asking yourself how I got that DVI port to play on an HDMI input. Here is the last item you need for that.
This DVI to HDMI cable sells for $20 on Ebay, and works perfectly on my TV. The one thing it won't do however, is play audio. That is because the Video card has no Audio chip for the HDMI cable to receive. You will be using a standard Headphone to RCA cable for that.
This simply hooks up from the speaker out on the PC to the audio input closest to the HDMI input.
The result is a multimedia PC that anybody can afford!
Enjoy!
If this tip was helpful to you please take the time to vote for me.
The original 250gb HD failed. I replaced it with a WD 320gb HD. I have tried to load the Lenovo restore DVD and a new, never used, Windows 7 DVD. Both drives take EXCEEDINGLY long to load (the Windows 7 took 23 hours!!!). Both display a pop up at some time during installation display an error message saying a certain file could not be found (different file names at different times). Seems like I may have a bad drive or something which causes read errors. What ya'll think? Thanks.
Welcome to FixYa!
It depends on how you used the recovery disc that you have, reinstalling operating system will not take 23 hours just like what you said so there's a possibility that you're having problem with the Operating System on your computer. Unfortunately, Lenovo will not provide a product key for the Operating System since the an OEM version. What you can do is reinstall the Operating System using the One Key Recovery Sofware or the Recovery Disc that came with the computer. Follow these steps for you to be able to reinstall the Operating System using the One Key Recovery.
1. Turn off the computer.
2. Press the little button near the power button, it usually do have a drawing of an icon that looks like a horse shoe or a headset.
3. There will be a window that will appear which do have three option, One Key Antivirus, One Key Recovery and System Setup. Choose One key Recovery.
4. There will be another window that will appear which do have two option, Restore from initial backup and Restore from user backup,Choose Restore from initial back up
5. It will asked you if you want to continue, Just click on OK or YES.
6. Once done, Reboot the computer.
For Recovery Disc,
1. Insert the disc inside the drive.
2. Turn off the computer then turn it back on and keep on tapping F12
3. There will a window that will appear which do have three options, HDD,ODD/DVD/CD, and NAT, choose ODD/DVD/CD
4. It will asked you to press any key immediately, you will need to press any key immediately so that it will boot from ODD.
5. It will asked you to choose a partition, choose Disc 0 partition 1
6. Reboot computer once done.
I hope this information will be helpful. Thank you for using FixYa...
May 16, 2011 | Lenovo IdeaPad Y510 Notebook
security systems go off at all hours please help
The security system (VATS/Passkey) installed on these GM cars is anti-owner more than an anti-theft. There are 3 parts involved:
  1. The chip-key
  2. The lock cylinder
  3. The TDM (aka the brain of the system)
if any of these parts fails or is even slightly malfunctioning, the car stays stuck where you are and you only get a dealer asking you about 1,000$ to fix it. And all the 3 parts have a quite short lifespan. Way too many people got in this situation (including myself). I don't recommend any partial solution or any used parts as it would happen again way too soon to be acceptable and if it happens 100 miles from home (like it happened to me....) it's a big burden. I finally made it to save my beloved 94 Park Avenue (with the exact same system that is installed in your car) with a solution that I found on the internet and that bypasses the entire factory security system, all 3 pieces altogether and you can even remove the TDM at the end and use 99c keys without chip. The product I used is at http://newrockies.com and is still working perfectly after 5 years. Don't go to the dealer!
Jan 11, 2011 | 1997 Buick LeSabre
how do i instal adobe flash player on ps3?
The PS3 browser comes with a built-in flash player.
Unless you install another operating system on it, you will not be able to install a newer version of flash player.
Updates to the PS3 (including its browser) are included in the firmware updates it gets automatically.
Jan 20, 2010 | Sony Playstation 3 (PS3) Console
Key and starting problems. Do I have a bad VAT?
If you want to keep the VATS system in factory working condition (normally recommended) then a VATS replacement is the answer IF the shops diagnosis is correct, BUT generally speaking ALL GM products built in that decade with the VATS system fail for the same reason sooner or later and it's not usually the VATS itself, but in the key resistor reading portion of the ignition switch.
My 97 Riviera had the same difficulty. Sometimes starts perfect. Other times is totally dead, not like a weak battery, but no fuel pump, no ignition, no starter at all. I noticed the 'security light was on on the dash and if I wait for 3 minutes the security resets itself and the car starts fine.
If these symptoms fit then it is the key reader and not the VATS itself.
There are 4 options if this is so.
1. Aggravation unlimited by putting up with it and waiting for 3 minutes whenever it won't start. (not recommended!!! drives you crazy!)
2. Replace the ignition switch and reader and keys (expensive, but the best all around solution if money is not a problem as it keeps your security system intact, around $250-300)
3. You can buy and install (or have installed) a VATS key reader bypass module. (also a bit expensive, like $150-200 installed)
4.My choice- I took my key to Radio Shack and read the resistance or the resistor. There are 12-15 different combinations. Then I bought 2 resistors that added up to that value + 5%. I soldered those together in line with bull nose connector ends. Then I pulled the lower steering column cover and found the 2 wires leading from the ignition switch reader. Be sure to disconnect your battery and leave the big yellow wire alone, that's the airbag!!! The 2 wires are usually run together inside a long outer sleeve similar to shrink rap and they exit the switch from a different position than the normal on/off/accessory etc. wires. Once located I clipped the wires leaving the switch leads dead and installed the matching bull nose connector ends and then plugged my resistors in line. The car now believes it has the proper resistance key inserted. The rest of the VATS system is not affected. Car starts every time!
This solution requires a little bit of time (took me 1 1/2 hours all in all) and just a little know how, but total cost came to $2.79 :)
Nov 13, 2009 | 1990 Oldsmobile Toronado
bypass validation tool
you need to download a programme called keychanger to install service packs if you have a pirated copy, but this is illegal and wil not allow any updates when installed. http://www.mike-devlin.com/windows/key.htm
Sep 25, 2007 | Computers & Internet
371 people viewed this tip
 Grubhead
Grubhead
