Tip & How-To about Computers & Internet
Testing a Laptop DVD-RW DVD+RW or CD
Have you ever tried repairing a laptop which has a failed Optical drive, only to discover later that the drive itself wasn't bad after all? The problem we face as technicians is that a wrong diagnosis will result in permanent ownership of that Drive unless the vendor is willing to take it back.
Not all Laptop Optical drives are created the same. Most models have a unique bezel design that will not fit correctly into another laptop due to the shape of the bezel itself. This will require removal of the bezel, and may break the retention clips that hold it in place.
A better solution is available however.
This adapter which sells on Ebay for a mere 99 cents with 42 cents shipping (at the time of this tip)
Will allow you to attach and test ANY IDE based Laptop Optical drive to your desktop PC with a standard IDE cable and floppy power connector.
This model incorporates Sata to Laptop IDE Optical Drive compatibility.
And this model converts Laptop SATA to Desktop SATA.
So as you can see, testing without Bezel destruction is indeed possible for Laptop Optical drives of any type without the risk of damaging another laptop in the process. All of these adapters are reasonably priced, and some are priced so low that you can't possibly afford not to have one if you are a PC tech like me. All models shown are listed on Ebay right now, but since most of them ship from mainland China you will have about a 2 to 3 week delivery date.
Hopefully this tip has helped you.
If so, please vote for me!
Computers & Internet Logo
Help my dvd drive is stuck and wont open
Desktop or Laptop computer wasn't stated.
With most desktop computer optical drive's there is a tiny hole located right under the optical drive tray.
(The tray the disk is inserted in)
A paper clip is straightened out, then inserted into the hole.
This is a manual override, and will open the tray.
There are some desktop computer optical drives, that the computer case has a door that flips down, then the optical drive tray comes out.
The door must be eased down far enough to see if the optical drive has the small hole.
With a laptop computer the optical drive is removed from the laptop.
Generally there is one small Philips head screw that is removed from the bottom side of the laptop, then the optical drive tray is opened with the paper clip, and the optical drive is then removed by using the tray as a handle.
The optical drive is then pulled straight out.
Once out the top cover is removed for access to the disk.
If this information is not what you seek, or you would like it explained, please post in a Comment, and we'll work together on finding a solution.
Regards,
joecoolvette
Apr 21, 2011 | HP Compaq Computer Speakers
RE-INSTALLATION PROBLEM
it doesn't seem to be cpu. have you tried to update bios? download usb bootable latest version of your bios and give it a shoot. if it does not help, try use external cd drive to reinstall os. press f9 at startup and choose usb hard drive. oh, one more thing-this may be memory corrupt, but not likely. test it in the bios.
Sep 09, 2009 | HP Compaq 6735s Notebook
trying to run recovery disc on computer and cd rom isn't reading
I see this as one of 2 possible failures.
  1. Optical drive failing. Take out the Hard drive, see if the recovery disk, or another bootable disk will boot. If no change, replace the optical drive.
  2. Hard Drive failing. If the system will boot to a CD with the HDD out or if replacing the optical drive has no change, then the HDD is the next logical failure point.
Apr 02, 2009 | Compaq Computers & Internet
hi , i m arhan khan .... plz send me dell service centre contect number & address in Delhi ...... my email ID 's mohdnoumaan2588@yahoo.co.in
Dell Laptop Service Centre in Delhi. Call Laptop
Call Laptop Clinic for genuine repairs of Dell Laptops.Pickup and delivery service at your doorstep.Just call or
Dell Inspiron,Vostro,Lattitude or any other model of Dell ,Laptop Clinic is a division of Beyond Computers, the most trusted name for the last 16 years.
.hidden {display: none;} .invisible { visibility : hidden; }
  • Dell Laptop AC power connector, broken, damaged, Loose, bad Motherboard ?
Having a Laptop problem? your computer does not boot-Up ?Laptop Clinic can repair a broken or damaged Power Connector. Give us a call at 098111 37536; it is possible to repair the connector assembly without replacing the motherboard.
  • Dell Laptop bad display, LCD Screen Broken or very dark display, No Display ?
If you have a broken laptop screen, You do not have to replace the expensive Laptop screen, it could be one component is bad or a loose cable. Let us check it out for you, before you replace the expensive Laptop screen or throw your laptop away.
  • Dell Laptop Bad Keyboard, or bad CD / DVD Optical drive, Hard drive and CPU Fan ?
We also repair Laptop Keyboard, CD / DVD optical drives, Hard drive CPU Fan and Housing repair.
Phone : 9811137536
Address : 2879 Sant Nagar Main Road Rani Bagh Near M2K Pitampura New Delhi
website : http://www.beyondlaptops.com
Feb 21, 2009 | HP Pavilion dv6000z Notebook
dell D600 turns onfor 4 seconds
That noise is typical of a bad hard drive. Are you sying the noise continues even with the HD removed?
Nov 20, 2007 | Dell Latitude D600 Notebook
605 people viewed this tip
David Payne
David Payne
