Tip & How-To about Computers & Internet
Netbook Hard Drive Repair for Solid state Drives
If you have either the Older
Asus Netbook
Or the HP Mini
with a dead or malfunctioning Hard Drive as many do, there is a cheap solution available for you.
These older models were sold with an electronic solid state hard drive installed that fails after it has been written to for a prolonged period of time. The replacement SSD (Solid State Drives) are usually very expensive and will definitely fail again. Most are manufactured in either 4 or 8 gigabyte sizes. Some larger drives were available optionally but the standard netbook usually has the smaller units.
Because of this, many PC repair shops have turned away customers they simply couldn't help, or referred them to the original vendor. Some consumers have even tried switching to USB thumb drives with very little success since not all thumb drives will boot, and even less can endure the multiple writes necessary for a proper paging file (Virtual Memory).
Since that time, Addonics Peripherals has developed a replacement carriage that utilizes a standard SD card such as the type used in digital photography and digital cameras. The size of the required SD card isn't limited at this time, so most High speed SD cards will do the job quite nicely. Standard SD cards DO work, but are a little slower.These drop-in replacement drive carriages fit in any Netbook with a standard Zif ribbon cable which most all of the older Netbooks have.
As you can see from the photo they compare in size quite nicely with the original SSD in your Netbook. This photo was taken from Ebay where the Chinese version of this device is substantially cheaper than the original model. This particular model has both the IDE and Zif connectors to ensure maximum compatibility with all major brand SSD based Netbooks.
The real beauty of this replacement though, is that should your drive ever fail you can simply replace the old SD card with a new one for a very small amount of cash. Also remember that while your Netbook is open you can make an instant backup of your Operating system with a second SD card which you can store in a safe place until it is needed. Optionally you can do the same thing if your Netbook is equipped with a memory card reader by cloning the drive. This doesn't always work, but it's worth a try.
Other types of cartridges use CF (Compact Flash Medium).
These are typically faster than all other replacement drive types, and some are actually mini hard drives in a CF case. The tradeoff, however is the price. CF drives are more expensive than SD memory, and are easier to damage. CF memory cards, however are more durable than many other types of Storage and are used in Ipods and Digital Video Cameras.
Other Carriage types and cartridges exist for Desktop PC's as well, like the one below.
Hopefully this has given you new hope for that old Netbook you thought was useless because nobody wanted to repair it. If you feel that this type of repair is beyond your ability, simply take the parts to your local PC shop and have them install the device for you. You will be doing them a favor by introducing a new idea to them and they may even be grateful enough to do it for free. You never know!
I hope this Tip has helped you fix your problem.
If it has please don't forget to vote for me!
Computers & Internet Logo
recover windows 7 mini 110 3130nr
take the big battery out first?
if F11 is dead that means, HDD bad, or corrupted.
reload from HP recovery media at HP, we are NOT HP.
it came new with W7 and never changed?
Sep 02, 2017 | HP XH021UA 110-3130nr Mini Netbook PC -...
windows XP will not start
The problem is corrupt windows or the hard drive is bad, if it can't be reloaded from the partition or cd disc the hardware should be suspect and tested.
May 30, 2012 | HP Mini Computers & Internet
I recover the operating system with hp recovery system, but once completed and restart the netbook, my hp mini 2140 never managed to come in and just boot windows back and forth. then I did the hard disk sanitizer but the results are now netbook I no longer recognize the hard drive on hp mini 2140, namely fujitsu 160GB. then I do install via flash drive but still does not recognize the hard drives on netbooks. please give the solution, now what should I do? thank you
Go into the BIOS by pressing f10 when powering on the laptop.
Go to System Configuration and choose Device Configuration
Scroll down to SATA Native Mode and disable.
Press f10 to save configuration. The computer should reboot and press f9 to select boot device.
See if the 160GB hdd is now showing as an option. If it is then you are in luck.
p.s: You may need to update the BIOS to the latest if it still does not show up for you.
Mar 01, 2011 | HP Mini 2140 Notebook
I am getting the error message-"Hard drive not
it caused the hard drive malfunction try open the bios and try to read the hard drive is your hard disk stll there. in some case on the hp compaq laptop the hard drive was detecting eror but it can be use to external hard drive.
you can find some usb to mini ata or usb to sata to try your hard drive on another laptop or pc(make it external hard drive)
Jan 14, 2011 | HP Pavilion dv5-1132us Notebook
dropped netbook now won't turn on. probably
if its just the hard drive thats no good, you can replace it for cheap. ebay always has good replacements. Check to see if it has a hdd or ssd and go from there.
Jun 30, 2010 | HP Mini 1000 Netbook
415 people viewed this tip
David Payne
David Payne
