Tip & How-To about Mitsubishi WD62627 62" HDTV
Fix for Mitsubishi WD-62627 going black and white
I found the solution to my problem and it has worked on two different Mitsubishi WD-62627 DLP rear projection HDTV's both with the same problem of the pictures going black and white after the sets had been on for about 20~30 minutes. I suspected that the color wheel might be the culprit. I removed the color wheels from both light engines and flushed out the back sides (where you can see the pulse coils in the back of the color wheel motor in the picture below) liberally with Ronsonal lighter fluid, which is basically naptha. I used lighter fluid for years in camera repair to flush out micromotors that would slow down or bind over time. The Ronsonol evaporates quickly and does not leave a harmful residue, however, I blew each one out with compressed air to make sure there was no liquid left. I then cleaned the glass on the color wheels, installed them back into the light engines, and installed the light engines back into the TV's. Both have been working fine for several weeks now. I do not claim this technique as a panacea but it has worked for me.
Greg
Mitsubishi WD62627 62" HDTV Logo
i need manual for mitsubishi dlp tv 62 inch model wd-62627
Owner manual or service manual?
Try to Google the model number for either or visit the Mitsubishi site for the owner manual.
May 21, 2012 | Mitsubishi Televison & Video
TV will not unlock channels over TV14
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
These steps are actually for the rear projection models, but I hope the work for dlp plasmas as well.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62627 Projection DLP TV help with PS3
To localize issue better try plugging your xbox into input for your ps3 and see what happens. You may have a bad input. Happens.
Aug 28, 2017 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
television is on but no sound everything else is working
Usually when you see a symbol like that, the speakers have been disabled. Is there a menu option for turning off the internal speakers? This option is different than Mute.
Jan 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
2,510 people viewed this tip
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
