Tip & How-To about Computers & Internet
Keeping external external hard drives safe from shock.
Generally, dropping an external hard drive while it is running is a pretty sure way to destroy the drive, along with the data that was on it. Similarly, objects dropped onto running external hard drives can provide sufficient G-forces to kill the drive and its data. Such events are generally not covered under product warranties. Perhaps more importantly, drives subjected to excessive G-forces usually present a situation in which data stored on them is not recoverable. If you use external drives to store or back up critical data, use extra care to prevent such accidents.
To prevent such unfortunate incidents, locate external hard drives so that they are not susceptible to being knocked to the floor, or to have objects fall on to them. Another cause of data failure is from improperly connected cables. Ensure that all cables associated with computers and their peripherals are firmly connected, and safely arranged so they cannot cause unexpected disasters caused by wayward feet and clumsy hands.
Computers & Internet Logo
How to dismantle my ADATA Classic CH11
Use something similar to an ATM card and pry open the bottom face. There are no screws but the faces are glued pretty good so it will take some effort.
Once the face is off, its pretty simple. About 4 screws to free hdd from the shell and then disconnect from the data connector
Aug 14, 2015 | ADATA CH11 500 GB USB 3.0 External Hard...
My Simpletech 500 gb external hard drive has been working fine for a long time, today it said something was corrupted and then the computer has not picked up on the drive, when you turn it on the blue light comes on and it sounds like its running, and then it shuts down
Sorry, but that sounds pretty bad. Generally when a hard drive bricks, its done. However you can try taking it in somewhere like the Geek Squad at Best Buy, and have them try and recover all your stored data from it. Good Luck!
May 17, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
my maxtor 250gb ext drive cant be read
Hi
Sounds like the armature of the drive has prob got damaged or the platters destroyed. If the data is important then maybe look into taking it to a data recovery specialised before its too late.
Do not attempt to pull apart yourself as ideally a 'clean Room' is required along with some pretty expensive kit.
Thanks
Taz
Oct 24, 2009 | Maxtor OneTouch II external hard drive...
dropped external hdd 2.0 320gb now doesn't work, is getting power.
Hard Disks are generally VERY fragile, especially the external drives simply because the read/write head inside is a very tiny substance. your case suggests that when it dropped, the read/write head might have got broken, and which means....you might have to get a new one. BUT in a very rare case however..you can do a funny and pretty nice trick, just get another one of the same type (Exactly the same type), then get A Very Good Engineer, and tell him to help you to transfer the read/write head to the former one, just for the purpose of retriving your datas...then return everything back to its normal place. HE HAS TO BE VERY CAREFUL THOUGH!!!, so as not to damage the two hard disks!
(How I wish I could be there to fix it for you, cos I've done it A LOT before...lol).
Hope this solves your problem.
Jul 10, 2009 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
178 people viewed this tip
David Payne
David Payne
