Tip & How-To about Microwave Ovens
HOW TO REPLACE THE DOOR OF A MACROWAVE OVEN
GeneralElectric is internationally known as a premier manufacturer of ranges,ovens, stove-tops and various other household appliances. ConsumerReports ranks General Electric appliances high on functionality andtheir low rate of repair. Currently, manufactures microwave ovensand wall ovens. Microwave oven doors are designed to be removed andreplaced by professional repairmen because a "leak test" must beperformed upon replacement to ensure ions are not coming off themicrowave's magnetron. With wall oven doors, removal and replacement bythe owner is a straightforward task that is safe for any owner tocomplete.
Here are step by step Instruction on how to fix in your microwave door below.
step1.
If your microwave door is cracked or the latch is broken, you may be able to replace it instead of purchasing a new microwave. Check the manufacturer's website to find out how to order a replacement door that is compatible with your specific make and model or visit any technician store that deal with microwave and oven around your local area to get one.
step2
Your owner's manual may also list a part number, which you can use as a reference when looking for a new microwave door.
step3.
Difficulty or note able part : Moderately Easy Instructions material needed Replacement door with Screwdriver a technician tool .
step4.
Unplug the microwave and set it on a table or workbench. If you have a built-in microwave, you may have to remove some mounting screws or retention clips to get the microwave out of the support bracket.
step5.
Open the door and take out the glass tray.Pry off a corner of the plastic panel on the inside of the door with a screwdriver or butter knife. Once it is loose, work the screwdriver or knife all the way around the glass and remove the panel.
step6.
Ask someone to hold the microwave door as you disconnect it from the hinges.
NOTE:
Depending on the design of your microwave door, you may have to remove a set of screws or slide a pin out of the hinge to release the door.
step7.
Remove and discard the old door. Have your assistant hold the replacement door up to the hinges.
step8.
Attach the door to the hinges by reversing the previous step. Snap the plastic inner panel into place around the glass.
step9.
Move the microwave back to its original location. Insert and tighten the necessary mounting screws if you are working on a built-in microwave.
step10.
Set the glass tray back inside the microwave and close the door.
Good luck.
Thank you and thanks for using visiting fixya.
Microwave Ovens Logo
microwave stops working after about 4 min. then comes back on after about 5 min.
does this happen when your cooking with the stove top, if so, then its causing the mircowave to be too hot.
Mar 12, 2011 | Maytag Appliances Over-the-Range Microwave...
my microwave intermittently fails to heat the food. Unit runs and lights up but does not heat up food. Microwave is 4 months old. Problem just started a few days ago. tried every combination of buttons, tried express & timed cooking, unplugged & re-plugged. . .
Hello there:
It sounds normal, but there's no heat When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Many over-the-range microwave ovens suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.
Dec 28, 2010 | Microwave Ovens
my microwave is not heating the food although its light is working and turntable is rotating
Hello there
It sounds normal, but there's no heat When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need to have the megatron tested and power inverter and associated parts tested to find out which one might be the problem
furthermore
microwave ovens can suffer from intermittent problems caused by excessive moisture from the range/stove entering the microwave cabinet and collecting on the circuitry. Often the problem is with one or two simple connections that may need tightening or soldering. But, to repair these components, the microwave cabinet needs to be opened. So we recommend that you seek the assistance of a qualified appliance repair technician.I
Dec 28, 2010 | Samsung Microwave Ovens
I have purchased a RV with a comb. amana radar range and need a manual to know how to operate it can you help the model no is AMV6177AAV? I don;t know how to operste it at all
Hello MJ hartman,
Here's a link that will take you to a free downloadable copy of your Owner's Manual for the AMV6177AA Series combination Microwave/Convection (over the range) oven.
http://shop.amana.com/assets/pdfs/literature/amv6177aa.pdf
I also have a folder on my computer that I've labeled "Household Appliances and Equipment" into which I save an electronic copy of all Owner's Manuals and Guides for all the appliances we have, just so they're readily available without having to spend hours searching the web for them, again.
I hope you find this Very Helpful and best regards!
Dec 14, 2009 | Maytag Microwave Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
346 people viewed this tip
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
