Tip & How-To about Cell Phones
MOBILE TIPS AND TRICKS PART-1
Reset Your Mobile Memory Card Password 2 minutes #fullpost{display:inline;}
We usually set password for our memory card for privacy and security, but the common mistake every one does at least once in out life time forgetting password. If you set password for mobile memory card, then you should be not forget the password. If you does then the only option is to formate your memory card with the help of the card reader and eventually the loss of all your data stored on it. There is a way to break the security wall. If you are a Symbian device lover then no need to worry about the password. You can crack them in few minutes.
In this tutorial I am going to teach you how to reset your memory card password in easy step. Before we start you need to have X-plore (application used to explore your system files and folder even the hidden folders in your device)
Step1: Install X-Plore in your mobile. If you want to download X-Plore search around internet you can download free trail.
Step2: Open your X-plore apps and Press 0(Zero) and check which you have marked the "show the system files"
Step3: Once you done that now go to the following path C:/Sys/Data/Mmcstore
Step4: Once you reached there you need to press "3" under option to set it in the Hex-viewer
Step5: See the third column you will able to see a line of code ! TMSD02G (c??"?x???6?2?6?2?6). Just check the character between the "?" it is your password ie: 62626
Note: If you have not set the password, then you will not able to gain access to C:/Sys/Data
Cell Phones Logo
I forgot my memory card password Nokia 5130, how can i unlock it? Help me please :((
Your can store your personal information or documentation of your mobile memory card. To protect your files or documents, you need to give a password on the memory card. It's a common mistake of human that most time they set password and forget that password. So, what to do then? Do you need to contact the mobile phone service center? It's a costly solution. Moreover, you have to spend enough time and effort to do that. All the peoples do their best to unlock the memory card and to recover the data. It's really a great annoying thing. But you can do it by yourself very easily. You just have to follow some steps to unlock your password protected memory card of your mobile phone. This page tells you the process of unlocking any password protected mobile memory card.
Steps to Unlock a Password Protected Memory Card of Your Mobile Phone
The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
Do your own risk..don't blame me try this links-
http://hubpages.com/hub/How-to-Unlock-a-...
http://www.mobilecubix.com
Apr 30, 2011 | Cell Phones
I forge me memory card passwor can any1 help me out ? Nokia x3
There are two methods:
Method 1 : Recover memory card password, using Fexplorer.
FExplorer software
As I said, we need to download Fexplorer software for this mobile hack. After installation, Browse to c:\system folder in your mobile phone. Here you would find a file mmcstore. This file is actually used to store memory card passwords in a mobile phone. Rename this file to mmcstore.txt and open with notepad. Now you will see the memory card password as it is, exactly. Mobile manufactures are now aware of this trick, and nowadays they use better encryption methods to block access to passwords.
Method 2: Unlock or reset memory card password of Nokia phones:
The first hack to recover the password of memory cards will not work on Nokia Nseries and Nokia Eseries devices. Here we will use the remote lock feature for re-setting the password. For this, go to your phones settings >Security >Phone and SIM> and then allow Remote lock. The password of your remote lock will be the password of your memory card. So if you want to change the memory card password, just send an SMS containing your remote lock message.
Nov 13, 2010 | Nokia X3 Cell Phone
my 2 GB Kingston memory card is locked. how to open it?
You'll need to reformat the card in order to reset the flash memory.
This is fairly simple to do. Simply insert the card into your card slot and go into My Computer (or just Computer in your start menu, if you're using Windows Vista or 7).
Next, right click on the icon that represents your card (this will be easily recognizable by looking at the capacity of the drive, it should be around 1.6-1.8 GB) and select "Format...". Format your drive using the recommended settings (usually FAT32, Quick Format) and you should be able to access it.
Mar 22, 2010 | Kingston 2GB Secure Digital Memory Card
My 512 MB Micro SD memory card is locked
Recently I wrote an article to recover deleted SMS from mobile phones . Here is another related one ,which deals with memory card password . We can use the same software that we used in the above case to recover memory card password from mobile phones .
Method 1 : Recover memory card password , using Fexplorer.
As I said, we need Fexplorer for this mobile hack .After installation , Browse to c:\system folder in your mobile phone . Here you would find a file mmcstore .This file is actually used to store memory card passwords in a mobile phone . Rename this file to mmcstore.txt and open with notepad . Now you will see the memory card password as it is ,exactly .
Method 2 :Unlock memory card passwords of Nokia Nseries and Eseries phones
The first hack to recover the password of memory cards will not work on Nokia Nseries and Nokia Eseries devices . Here we will use the remote lock feature for re-setting the password . For this , go to your pones settings >Security >Phone and SIM> and then allow Remote lock . The password of your remote lock will be the password of your memory card .So if you want to change the memory card password , just send an SMS containing your remote lock message .
u can also download from this site
http://www.mobiclue.com/2009/02/recover-memory-card-password-from.html
Nov 28, 2009 | Cell Phones
I have E250, i put 512 mb memory card in it, my phone is asking password to open memory card. but there is no password on memory card, i checked that memory card by putting on different cells.
it's in you phone's settings. go to menu then settings (9), go to security (7) and then privacy.. there, you'll see those menus that you'd like to put passwords on. uncheck memory card then press save. put your security code and that's it! you can now use your memory card
Jul 08, 2009 | Samsung Cell Phones
186 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
