Tip & How-To about Clothing Accessories
Tip on shoe maintenance.
.You can maintain the shape of stored shoes by packing them full of newspaper. This will also absorb moisture, and it's a great way to reuse old newspaper.
Clothing Accessories Logo
Lumix DMC-ZR1 / DMC-ZX1 Digital Camera: My lumix dmc-zx1 got wet with normal sweet water t...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need to take out all moisture trapped in the camera. You could do this: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Did you dry the camera completely? If not here is the procedure to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs. Hope this helps!
May 17, 2010 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
S3650 Corby / S3650 Genio Touch Cell Phone: it felt into a bucket full of water...
First of all, do not turn it on, you could make more damage. Next, take out the battery, and completely dry the phone before trying to use again.
Here is the procedure to take out all moisture trapped in the phone: Dry the phone, battery, any accessory, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
May 17, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
water in my camera
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Did you dry the camera completely? You could follow this procedure to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth and wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs. Hope this helps!
May 17, 2010 | Fuji FinePix F610 Digital Camera
How to fix a phone dropped in water?
You may not be able to rescue this but it's worth a try.
First thing is to remove the battery or battery pack. Take the back cover off and take out the batteries.
If you can, take the cover of the phone apart - this is not always easy. There may be some screws inside the battery compartment, so remove those. You may now have to carefully prise the two halves of the casing apart. If it's not obvious how to do that then leave it alone.
You now need to leave the phone on a warm place for at least a week to allow all moisture to evaporate, before re-installing the batteries and re-charging.
Mar 31, 2010 | Uniden Cordless Phone
mold
Desiccant Moisture absorbing packs will help to absorb some of the excess humidity in the safe. In addition to the desiccant packs, you should open the safe at least once every two weeks for approximately 20 minutes. To alleviate some of the musty odor, we suggest that you remove the items from the safe and wipe the interior with a paste of baking soda and water. Do not store your safe unit in areas of your home or business with already high humidity levels such as a basement or cellar as this will add to the moisture problems. You can purchase desiccant packs from www.SentrySafeShop.com . The link for the desiccant packs is: http://www.sentrysafeshop.com/Moisture-Control-Desiccant-Packets-p/desiccant%20pack.htm
Oct 31, 2008 | Sentry Fireproof Safe
1,145 people viewed this tip
Top Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
