Tip & How-To about Clothing Accessories
Tip on how to shine patent Leather Reebok Shoes.
1. Clean your Reebok patent leather shoes with mild soap and water to be sure they are free of debris before shining.
2. Pour a few drops of mineral oil onto a clean, lint-free cloth.
3.Buff any scuffs on the surface of your patent leather Reeboks with mineral oil first. The mineral oil will help repair the scuff marks so your shoes look unblemished.
4.Add a few more drops of mineral oil to the cloth and rub the cloth over the entire shoe. Use circular buffing motions to make the shoe shine
5.Allow the oil to settle into the leather overnight before wearing, as wearing them right away could encourage dust to collect on the surface
Clothing Accessories Logo
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
Oct 31, 2011 | Whirlpool Washing Machines
How do you clean the Ecco Glide shoes?
Ecco Glides are good shoes, made of leather, not cheap plastic imitation leather. In the household aisle of the grocery store or a big-box (Wal-Mart or Target) store, find a tin of saddle soap. It's specifically designed for cleaning leather.
Follow the directions on the soap, but mostly it boils down to three steps:
1. Use a moist/damp rag and get most of the dirt off.
2. Use a (clean!) damp rag to rub a small amount of saddle soap all over your shoes. Rub it in well.
3. Use a (non-soapy!) damp rag to remove the soap.
Apr 30, 2011 | Ecco Glide Shoes
How do I clean my Timberland Stormbuck (Nubuck) shoes?
  • Purchase cleaning products and brushes directly from Timberland. Their products are designed for suede, leather and nubuck.
  • Go to a shoe store like Footlocker and ask for the products they carry to clean your Timberland boots. Some sell kits and others carry suede erasers to clean the boots.
  • Wet a rag and wipe it all over the surface of the shoe. Spray on shoe cleaner and rub gently with a sponge. Rinse and let dry. Timberlands dry quickly.
  • Use a soft brush to scrub away excess dirt. Hold the boot over steam as you scrub.
  • Try baby wipes to clean your leather Timberland boots. They'll moisturize the leather and clean off grime.
  • Put your boots on, and use a wet rag as though you were giving yourself a shoe shine. Finish the spots you couldn't reach with a brush.
  • Use mink oil or saddle soap on leather boots. Both will keep the boots waterproof. Work either into the leather with a soft rag.
Mar 08, 2011 | Timberland City Adventure Stormbuck...
411 people viewed this tip
Top Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
