Tip & How-To about Samsung SCH-U450 Cell Phone
How to pair a Plantronics Explorer 245 Bluetooth headset and a Samsung Intensity cell phone
To pair a Samsung Intensity cell phone with a Plantronics Explorer 245 headset, follow the 10 steps below:
1. Turn your cell phone on and your headset off.
2. On the Intensity, press the Menu button (the center round button) and from the main menu, go to Settings & Tools (in the bottom right corner).
3. Select item #3, Bluetooth Menu.
4. Select item #1, Add New Device.
5. If your Bluetooth radio is currently off, you'll be asked if you want to turn it on -- select Yes.
6. Turn on the Explorer headset. After a few seconds you should see either red and blue flashes or just blue flashes. If you see red and blue flashes, go on to step 7. If you see only blue flashes, hold the Call button down (the button on the side of the earpiece) for five or six seconds, until the LEDs begin to flash red and then blue.
7. On your cell phone, click OK on the screen telling you to place your device in discoverable mode.
8. The phone will search for Bluetooth devices in the area, and the Plantronics headset will appear at the top of the screen. It should be labeled "245Plantronics" or something similar. Once you see the headset appear on the screen, press the menu button to stop the search.
9. Press the menu button again to pair the two devices.
10. A message will appear once pairing has been completed, and you will be prompted to connect the phone to the headset. Select Yes.
The connection has now been established between the two devices, and you can use your Explorer 245 as a hands-free headset in conjunction with your cell phone. To see information about the headset (such as what services it offers, what its Bluetooth address is, or how long it has been paired to your phone) scroll down to its name on the phone's Bluetooth Menu and click the right option button to bring up the device's Options screen.
Samsung SCH-U450 Cell Phone Logo
I am trying to pair my Plantronics Explorer 220 ear piece to my samsung At&t cell phone, It can not find the passcode # 0000,1111,9999 or 1234. Is there another code i can use?
Step One:
Prepare Phone-
Turn on Bluetooth
For most phones, go to Settings/
Tools menu and select Bluetooth
or Connectivity and select "On."
(Or see the user guide for your
phone.)
SETTINGS
Time and Date
Phone Settings
Bluetooth
Sound Settings
Network Services
Security
Reset Settings
BLUETOOTH
Discover/
Search
BLUETOOTH
220Plantronics
Headset Passkey
PASSKEY
0000
Step Two:
Prepare Headset-
Pairing Mode
Begin with headset turned off. Turn
headset on (hold call control button
for 2 seconds until the light flashes
blue) and it will automatically go
into pairing mode, flashing red
and blue.
Step Three:
Pairing-
Add Headset to Phone
For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device,
then Select "220Plantronics."
For passkey enter 0000. Headset
will flash blue when paired
successfully. It is now powered on
and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with
another device, follow pairing instructions on the next page.
Apr 20, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How to connect it to samsung seek cell phone
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Mar 31, 2011 | Plantronics Explorer 320 Wireless Headset
How do I pair it with my cell phone??
Nov 07, 2010 | Plantronics Explorer 330 Headset
I need the access code to pair it to my cell phone.
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
So - 0000 (four zeroes)
hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Nov 20, 2008 | Plantronics Explorer 220 Bluetooth Headset...
3,432 people viewed this tip
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
