Tip & How-To about RIM BlackBerry? Tour 9630 Smartphone
How to pair a Plantronics Explorer 245 Bluetooth headset and a BlackBerry Tour
The Plantronics Explorer 245 headset can be paired with most Bluetooth-capable phones and smartphones to enable hands-free phone conversations. To pair the headset with a BlackBerry Tour, follow the steps below:
Make sure the Plantronics headset is off before trying to pair the two devices. On your BlackBerry, scroll down to Manage Connections (the antenna icon) in your Home folder and click the trackball. From the list of connections, select Set Up Bluetooth. The Add Device box will appear, asking if you want to search or listen for a Bluetooth device.
At this point, turn your Explorer 245 on by sliding the on/off switch toward the microphone end of the earpiece. Once the device powers on (if you have it in your ear, you'll hear a few short tones) you should see repeating red and blue flashes from the LED lights on the side of the headset. If you only see blue flashes, hold down the call button (the side button) for a few seconds, until the lights start flashing red then blue.
Now, on your Tour, select Search. Bluetooth will be enabled if it's not already, and then the BlackBerry will search for nearby devices. When the headset appears on the list of devices found (it should read "245Plantronics" or something similar) select it. A box will appear letting you know that pairing is now complete, and asking if you want to connect to the headset. Select Yes.
Your BlackBerry Tour and Explorer 245 are now paired. If at any point you turn the headset off, turn the BlackBerry off, or turn the BlackBerry's Bluetooth feature off, the two devices will automatically reconnect when they are able. When you look at your list of paired devices on the BlackBerry, the Explorer headset will appear in bold to show that it is currently connected.
RIM BlackBerry? Tour 9630 Smartphone Logo
the headset connects to the phone but then it says connecting and then comes up bluetooth connection failed and it wont work hands free, it has the blue symbol on my phone screen but wont it wont connect to the earpiece, what am i doing wrong?
I would suggest turning off your phone and headset. Turn your phone back on and put the headset into pairing mode (the headset needs to be turned off when starting the pairing mode) pull up your menu on your Bluetooth phone and try reconnecting the two again.
Below is the Explorer 320 User's Guide for more information.
Plantronics Explorer 320 User's Guide
Good luck from Headsets Direct!
Apr 27, 2011 | Plantronics Explorer 320 Wireless Headset
My blackberry bold phone does not locate my Plantronics VBH-300 bluetooth headset whilst trying to pair them. It was paired with a previous nokia phone,which I no longer have.
Hi,you will have to delete the previous paired phones first before you can be able to pair the blackberry phone with your blue tooth device.
You can use the below steps to know how to pair properly:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Hope it helped.
Thanks for usingf ixya..
Jan 13, 2011 | Plantronics Explorer 320 Wireless Headset
can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
7,516 people viewed this tip
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
