Tip & How-To about Computers & Internet
How to Reset Your BIOS
*Power down your PC.
*Remove the cabinet cover
*Find the 3-pin jumper near the power supply on the motherboard, typically labeled "clear cmos" or "reset bios".
*Remove the jumper from the default position (typically connecting the 1st and 2nd pins).
*Replace the jumper to connect the 2nd and 3rd pins.
*push the power button of ur pc once
*After a min Return the jumper to its default position, connecting the 1st and 2nd pins
* Turn on the PC now,
Computers & Internet Logo
I have dell CPX H500GT and lost BIOS password
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
hope this helps
Feb 27, 2011 | Computers & Internet
forgot the password and cannot start my laptop
Hope this helps
hope this helps
Jan 25, 2011 | Computers & Internet
i need to reset the bios password on my metrobook ltplus
At his time you need to open the back cover of you laptop to solve the problem. You need to reset the CMOS battery of jamper to clear BIOS password. To open the back cover you need to remove first the laptop battery after that fine and remove some screw.
Once you have already remove the screw and the cover you can see there a small circle CMOS battery you need to remove is to clear all stored password in CMOS memory. You can also see there a jamper near the CMOS battery just remove that and turn on your laptop with in 10 seconds and turn off. Reinsert the jamper with the same position.
Now the CMOS password are already clear just turn on your laptop first before you close the cover.
Oct 25, 2009 | MetroBook DT Plus PII-300 (MB-DT-P300) PC...
how do you reset or bypass cmos password on msi wind u100 notebook.
hi this is kamal..
pls follow these steps:
There are 2 ways you can reset your bios.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
best regards
kamal singh
Oct 09, 2009 | Computers & Internet
how to remove cmos/bios password ?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
289 people viewed this tip
David Payne
David Payne
