Tip & How-To about Vacuums
How to fix you're Dyson DC08 Turbine Head
I have a range of other Vacuum how to's listed over at squidoo! If you like one please take a moment to comment of give it a thumbs up.
I work as a technition for vacuumspot.com.au & nelsonvacuums.com.au fixing vacuum cleaners. It is a common problem for turbine or turbo heads to slow down or stop altogether. I'll show you how to look after them and avoid costly replacement.
Start by turning the head over. I have marked the 3 points you need to undo to take off the base plate. Simply twist the 2 knobs and slide other catch in the centre of the head. The base plate should now lift off quite easily.
Have a good look in the spot where I have marked it is very common for dirt and fluff to stick to the sides of the rubber part in the middle. This can reduce the suction at the head and reduse cleaning effiency.
Now you have to pull the brushes out to the sides, they should come off easily. Clean really well around the shaft pay particular attention to any hair wound around the small gap marked. Anything caught here gradually works it's way to the bearing which sits just inside the housing here. If the bearing gets worn you have to replace the entire head as there are no spare parts for this tool. :(
DO NOT try and put a lubricant on the shaft, it will work for a short time but in the longer term it will only attract dust to the bearing.
This part is easy, just tap out the the dirt from inside the brushes. If you have another vacuum handy this will work well too. An air compressor will do the best job but make sure you direct it away from yourself.
Give the base plate a basic clean, there is normally not a lot of stuff here but if you get dirt caught around the edges it can affect haw well the plate seals to the rest of the head. One thing to take particular not of is the rubber seal that goes around the edge. It often gets dislodged, just poke it back in or if you have gasket adhesive put a small amount in the groove to hold it in place.
Now check the filter on the side. You only have to give it a wipe with your finger or a dry cloth to keep it clean.
There you have it all done. Simply pop the brushes back on making sure you put them on the side they came off. There is a little arrow marked on the brushes and centre of the head if you forget. Then put the baseplate back on and fix the catches back in place.
If you do this every month or two your turbine head will spin at max speed all the time and last longer too!.
Hope this helped you and feel free to leave a comment, I love feedback
Vacuums Logo
I want to clean the cyclones on my DC07 Dyson How do get the yellow top off of the glass bin?
Hi there I have made a video to show you how to clean out the radix tubes on a Dyson DC07 vacuum cleaner. If it is helpful to you please take a moment to give me a thumbs up or even write a testimonial. If you need to get filters or other parts for your Dyson DC07 check out vacuumspot or nelsonvacuums.
Nov 25, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson DC07 keeps cutting out. I have seperated the cyclone from the bin, how do I clean the cyclone as I think this may be the cause?
HI there,
This is a tricky solution to describe so I have linked a video I made on how to clean the radix assembly of a Dyson DC07. Have a look at the video it should be pretty clear what you need to do. If you find you need parts for your Dyson check out Nelson Vacuums or VacuumSpot.
If this is a helpful video please take a quick moment to give me a thumbs up, a comment or a testimonial I like to hear back from you guys.
Nov 05, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
brushbar is not spinning
There is really only a couple of reasons for the brush not to spin.
1. The brush roller bearings are siezed
2. The clutch is faulty and not engaging
3. One of the belts is broken
I have made a video to show you how to access al these areas, watch it first to see if you are comfortable doing the job before you start out.
If it is a helpful video please take a moment to leave a comment or a thumbs up.
If you find you need parts check out nelson vacuums or VacuumSpot.
Hope this helps
Oct 16, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
tHE ON / OFF SWITCH IS FAULTY , HOW DO I GET INTO IT TO FIX
Since it's a pretty long explanation to show to open a dyson DC08 I have made a video instead. I use the video to show how to change a motor so if you only need to change the switch you will only need to watch half of it. If you like the video please take a moment to give me a thumbs up on youtube or better still leave a comment here on fix ya. If you need parts I would recommend visiting Nelson Vacuums or VacuumSpot.
Oct 12, 2010 | Dyson DC08 Cylinder Bagless Canister...
I have a dyson dc07 that works fine in the vacuum position, but loses all suction in the hose when it's upright. I've checked every removable piece and everything is clear. I can't figure it out! Help!
Hi there, I have a suspicion that you are actually missing a piece called a u-bend. I have made a video to show you how to fault find this problem for the dyson dc07. If you need to get a new piece for your vacuum I would recommend vacuumspot or nelsonvacuums.
If this was a helpful post for you please take a moment to write a testimonial or give me a thumbs up.
Vacuum Guru :)
Aug 23, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
6,589 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
