Tip & How-To about GPS
How to Update a Garmin Nuvi GPS
Below are steps to successfully update your Garmin Nuvi GPS;
Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
Open your Internet browser of choice and type in the following web address: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27"
Download the appropriate version of the software for your computer (Windows or Apple) and Install the Web-Updater by following the wizard (accept defaults).
Click "Start," "Programs," "Garmin" and " Web-Updater" to update your firmware and your maps. Periodically check and make sure your software is current.
Good luck.
GPS Logo
my gps turn off end turn on by self
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck
Jan 04, 2012 | Garmin nuvi 1490T GPS Receiver
lukeng for new abdates
Do you mean looking for new updates? If yes, follow the steps below;
Good luck....
Mar 03, 2011 | Garmin Nuvi 265W GPS Receiver
PLEASE talk me through as to how to update my Garmin 200W series...
Click "Start," "All Programs," "Garmin" and " Web-Updater" to update your firmware and your maps. Periodically check and make sure your software is current.
Good luck.
Oct 24, 2010 | Garmin nuvi 200W GPS Receiver
where can I get free map updates for Garmin nuvi 200???
Follow the procedures below on how to update your garmin nuvi map for free:
Good luck
Sep 08, 2010 | Garmin nuvi 200W GPS Receiver
will not load map. I plug it in an it starts and will not shutdown. Just says loading maps
Take care.
Jul 20, 2010 | Garmin nuvi 255W GPS Receiver
427 people viewed this tip
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
