Tip & How-To about GPS
How to Soft Reset and Hard Reset a Garmin Nuvi GPS
In case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset (Soft Reset)
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset (Hard Reset)
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Good luck
GPS Logo
my gps turn off end turn on by self
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Good luck
Jan 04, 2012 | Garmin nuvi 1490T GPS Receiver
frozen just tried to update and froze up brand new
Good luck
Dec 26, 2011 | Magellan GPS
reset
Good luck
Dec 06, 2011 | Garmin Nuvi 1490T 5.1 in. Car GPS Receiver
hard reset
Good luck...
I cannot find a reset button on my nuvi 250w. Where is it? (Owners manual is lost)
Take care.
Jan 12, 2011 | Garmin nuvi 250W GPS Receiver
524 people viewed this tip
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
