Tip & How-To about Motorola Mobility V500 Cellular Phone
Trouble viewing my screen
Every time I flip open my phone to use it or answer a call the screen stays black just like it does not realize that I flipped it open. In order to use my phone I have to push the buttons near the top of the phone by the menu button repeatedly to get the phone to realize that it has been flipped open, also my charger port is acting funny too I plug in my cable to charge it and it does not realize that a cable has been plugged in. I have to literally bend the cable around different ways for the phone to realize that it is plugged in to the charger... Please help!!!!!!!
Motorola Mobility V500 Cellular Phone Logo
can i stop the alcatel one touch 665 from playing a tone when i open and close the clamshell
Goto Menu then Profiles you see a red dot on General. Press options on lower left of screen and Edit. scroll down to Flip Beep and click it then scroll to Silence and press Select on lower left of screen. It worked for me.
Nov 20, 2011 | Cell Phones
Phone doesn't answer when flipped open
Hi
The phone did not answer when flip up because you did not activate it.
To activate go to call, go to answer by flip and click yes.
Any time a call come in and you flip it will answer.
Aug 18, 2010 | Motorola Mobility W385 Cellular Phone
The screen on my Pantech Impact is black..i can make calls, text, listenin to music, & stuff thanks to the touch screen part of the phone. But when i flip it open the screen is black. So i cant take pictures or go on the web. Ive tried taking the battery out/turning my phone off for several hours. & sometimes,when i turn it on,the screen is back to normal. but as soon as I close it, & flip it open again,the screen goes black. So what can i do to solve this problem? Can i solve this problem without taking it to get repaired? Please answer as soon as possible! Please & Thanks for taking the time to read this. & for replying (if you do). Thanks so much!
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 10, 2010 | Cell Phones
screen is dark when I flip it open
Change LCD flex it will fix the problem link
Oct 15, 2009 | LG Shine KE970 Cellular Phone
The outside camera on my phone always comes on in my pocket. How can I put my outside camera on lock and still use my camera while my phone is flipped open??
this might work it did it to mine 2, the camera button on the side might be jammed. try to unjam it. another problem is that it might be to sensitive
May 28, 2009 | Verizon Communications LG VX8350 Cell...
1,664 people viewed this tip
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
