Tip & How-To about Garden
Onions last longer if
Take a clean discard pair of stockings and place an onion in, letting in fall to the toe then tie a knot just above the onion and add a second onion. Repeat untill full the hang in a cool dry place. As you need an onion simply cut off the bottom onion leaving the knot to hold the remaining onions.
Garden Logo
can I oven bake oxtail from frozen
issue i see is will take longer to cook
ox tail normally thawed before cooking
oven baking dish or pot or slow cooker is another option with lots of water and vegies etc
into a frying pan browned all over to seal in flavor and juices
Use tongs to remove oxtails to a plate, setting aside.
2 Saut? onions, carrots, celery: Add the chopped onion, carrot, and celery to the pan.
Cook for a few minutes until onions are translucent. 3 Add oxtails, garlic, bay leaf, thyme, salt, stock, wine, then simmer: Add the oxtails back to the pan.
let me know when dinner is ready
Jan 14, 2017 | Ovens
I take an old pair of hose (womens), buy some loose tobacco, cut the hose to about 1 foot, 30cm long making sure there are no holes in the toe or elsewhere, put a 1/4 cup or so of tobacco into the sock, tie a knot so the tobacco stays put. Then open the bonnet of the car, find the windshield wiper water tank, drop the end of the sock into the solution or plain water, make sure the upper end of the sock is securely fastened to something outside the tank so you won't loose the bag you created and you'll be amazed at how clean the windscreen will be next time you use the wipers after squirting the windshield as usual. An alternative would be to boil the sock in water like tea, but don't drink it! after 10 minutes of boiling, let it cool, squeeze the bag so all the "tobacco tea" goes into the pot. When cooled, pour it into your windscreen water tank. As you wash your windscreen with the wipers going the squirted liquid will clean the glass and make rain water sheet off rather than leave droplets. You can actually drive the car safely because you can see as if no rain was falling. If your wipers stop working all together and you can't see to drive, take a sock, as the one I described above, get it wet and wipe the windscreen with it. The rain will then sheet off the glass as if there was no rain at all. no drops can form. The tobacco breaks the surface tension. Want proof? Take a glass of water, fill it to the top just short of spilling over. You'll notice the water actually rises above the edge drop one grain of tobacco or black pepper and the glass will immediately spill the water out of the top of the glass. I keep such a bag in a plastic bag under my seat. You never know when you might need it. You can use it many times before needing change the tobacco. If you just want some cheap glass cleaner, mix a 50% solution of white vinegar and pour it in your window wiper water tank. It will keep your windscreen nice and clean; also streak free.
Jun 14, 2010 | Kitchen Appliances - Others
how do I make a knotless knot
I assume your using wire cable. Termination ends are available and a special set of pliers are required.
Sep 28, 2014 | Fishing
Do you have to tie a necktie or you can just put it on?
You have to tie a necktie. but I heard that there are some ties you can buy that you can just put over your neck. however you should know it does not look the same as a nice tied tie
Jan 10, 2013 | Clothing Accessories
KREEPY-KRAULY Ties itself into a knot while cleaning.
Solution:
We removed 2 portions of hose located at the Krauly end, and attached those at the filter end, then we took the 2 portions located at the filter end, and placed those at the beginning of the Krauly end.
Apparently the problem was that the 2 portions of hosing at the Krauly end had become "twisted" and continually enabled the Krauly to move in the knot tying direction. By replacing these 2 portions at the Krauly end with "un-twisted" portions from the filter end, this ended the twisting cycle.
The Krauly has been running for 48hours straight now without a single knotting episode.
If we see the knot tying direction beginning again, we will repeat these steps, continually replacing with un-twisted portions.
At 1st we thought we needed to purchase some new tubing, but we didn't have to, only needed to move around some hosing.
Jan 03, 2010 | Pentair Kreepy Krauly Inground Automatic...
849 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
