Tip & How-To about Computers & Internet
SKYPE VIDEO PROBLEM
SKYPEVIDEO PROBLEM
To test if the WEBCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - your model WEBCam and see if you can get the WEBcam to capture your image/video. If this works then the fault is with the Skype video configuration. Sometimes the WEBcam settings drops off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select your model WEBCam.
Also check the Audio Settings for your model microphone THEN click on Save.
Avoid connecting the WEBcam to an USB hub, connect it to the USB port on your computer.
Computers & Internet Logo
my chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
webcam not working with skype
SKYPE VIDEO PROBLEM
To test if the WEBcam is functioning, check the USB cable; make sure itis connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture yourimage/video.If this works then thefault is with the Skype configuration. Sometimes the WEBcam settings drop offand the WEBcam need to be selected again. Open Skype - Tools - Options - VideoSettings and select the WEBcam Also check the AudioSettings for the Microphone THEN click on Save.Avoid connecting the WEBcamto an USB hub.
Feb 21, 2012 | eMachines Computers & Internet
my webcam doesn't work to my skype, what's the problem?
To test if the A4Tech WEBcam is functioning, check the USB cable; make sure itis connected properly. Then check the Skype configuration. Sometimes the WEBcam settings drop offand the WEBcam need to be selected again. Open Skype - Tools - Options - VideoSettings and select the A4Tech WEBcam Also check the AudioSettings for the Microphone THEN click on Save.Avoidconnecting the WEBcam to an USB hub.
Sep 07, 2011 | A4tech PK-635 Webcam
I am not a computer person.I was wondering if logitech webcam C250h will work with skype?
Yes, I have a Logitech WEBcam (not the same model) and I use Skype.
After you installed Skype then :-
Mar 09, 2010 | Logitech Webcam
my camera quit working in skype, any suggestions in troubleshooting? the green light isnt coming on at all, it was working like 5 minutes ago
To test if the Logitech QuickCam is functioning, check the USB cable, make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video.
Dec 14, 2009 | Logitech QuickCam Connect Webcam
857 people viewed this tip
David Payne
David Payne
