Tip & How-To about Office Equipment & Supplies
Service mode entering
To enter the service mode for canon IR5800C & IR6800C type :
  1. *
  2. press at the same time from keypad these number 2 8
  3. *
Canon iR6800C printer error code E000002-0001 pls fix this error code on photo coppier machin
Hi. You have to clear that error from service mode
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
Mar 28, 2015 | Canon Office Equipment & Supplies
service manual canon c2020h
Dear
To enter service mode
1) Press the User Mode key.
2) Press 2 and 8 on the keypad at the same time.
3) Press the User Mode key on the control panel.
Then press COPIER>FUNCTION>CLEAR>ERR.
And make power OFF and ON.
Hope this may help you to get clear.
Thanks.
Feb 13, 2015 | Canon Office Equipment & Supplies
canon ir2870 error code e000002
these means that in fixing assy is low temperature. It can be that you only need to clear the error trough service mode, or you need to change thermistor.
To clear the error:
enter the service mode:
1) Press the asterisk key " * " on the control panel
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " " on the control panel.
then choose COPIER, then FUNCTION, then CLEAR and choose ERR. Shut down and back ON the copier.
If these doesn't helps, replace thermistor which is inside of fixing film ceramics.
Jun 12, 2011 | Canon Office Equipment & Supplies
146 people viewed this tip
k24674
jasbo
jasbo
