Tip & How-To about Computers & Internet
How to replace the Hard disk in Dell inspiron 1525:
* Turn off the computer and take the battery off the computer
* Now keep the laptop in such a way that the battery side is at the bottom
* Now see towards the top left hand side
* The Hard drive will be holded with two screws on the side
* Take the two screws off the Hard drive can now be slided out of the computer
* For reinserting the hard drive - slide the hard drive in and put the two screws,battery back in place
* This is the simple steps that you can use to replace or take the hard drive off
Computers & Internet Logo
bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
Purchase the battery through Acer or a local or online computer parts dealer.
Turn the laptop off and unplug it.
Also unplug any external hard drives, cameras or other external devices.
Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Installation
Plug the new CMOS battery cable into the motherboard.
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
http://support.acer.com/us/en/default.aspx
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Jul 24, 2013 | Acer Aspire 5100 Notebook
how I can turn on my computer , I press down the power bottom and it lights on but as soon I remove my finger it turn off
Seems, your battery is wear down. Please replace the battery and re try your laptop. Otherwise just keep your power adapter stay on then turn on your laptop
Jan 05, 2011 | Apple Power Mac G5 Desktop
reseat hard drive
Use the following steps that are very helpfull
Dec 05, 2010 | Dell Inspiron 1525 Notebook
where is the cmos battery located in the computer??????????
#1
Turn off the laptop and remove the AC adapter. Remove the battery from its compartment on the bottom of the computer. Turn the laptop over and remove the screws holding the DVD drive in place and pull out the DVD drive.
#2
Remove the remaining screws on the bottom of the computer. These screws secure the wireless card cover, the memory card cover and the modem card cover. Then remove all of the plastic covers. Remove the wireless card by sliding it gently out.
#3
Remove the corner screws on the bottom of the laptop securing the bottom housing. Remove the housing by pulling it away from the laptop. Remove any remaining, exposed screws on the bottom of the computer.
#4
Turn the laptop over and remove the thin plastic strip that runs along the border of the keyboard with your fingernails. If your fingernails aren't long enough, a plastic card will work as well.
#5
Remove the two screws on either side of the keyboard securing it to the computer. Remove the keyboard.
#6
Remove all of the exposed screws where the keyboard used to sit. These screws secure the top housing to the computer. Remove the housing, exposing the motherboard.
#7
Locate the CMOS battery. It is a small battery about the size and shape of a coin and should be easily visible on the board. Depending on the model of Toshiba you are working on, the CMOS battery will either be secured with a clip or connected to the board by two small cables. Either way, they are easily removable.
#8
Disconnect the battery by pulling gently away from the cables or by popping the clip out. Your CMOS battery can now be removed
Oct 06, 2010 | Toshiba Satellite X205-SLI1 Notebook
Plugged in, not charging toshiba
Turn off computer, take out charger, then try taking the battery out of the laptop (located at the bottom of the laptop) or side then re-insert and turn on laptop and plug charger back in. Hope this works! if not you either need a new charger or new battery, I suggest u find someone with a toshiba charger to test if it is a problem with the charger or your battery! keep me posted! and good luck
Feb 02, 2010 | Toshiba Satellite A135-S4527 Notebook
147 people viewed this tip
David Payne
David Payne
