Tip & How-To about Computers & Internet
How to replace the Hard disk in Dell Mini Laptop:
* Turn off the computer and take the battery off the computer
* You will have three screws below the below the battery - Take them off
* Then open the laptop and try to take the keyboard off the computer
* The keyboard will have a strip in the backside - Please take it out of the strip carefully
* Now you will be able to see the hard drive in the left side under keyboard
* Take the two screws holding the Hard drive
* After you replace the hard drive - connect the keyboard strip and put the keyboard in place
* Back of the laptop put the three screws and then the battery back in place
* This is the simple steps that you can use to replace or take the hard drive off
Computers & Internet Logo
HELLO: I HAVE A REMINGTON R-9500 IT WONT TURN ON SO I OPENED AND NOTICE THAT ONE CIRCUIT AND THE BATTERIES ARE CORROTED ALSO SOME TIMES THE SHAVER BECOMES EXTREMELY HOT PLEASE HELP ME IS A BRAND NEW
Model R-9500 has been discontinued for several years. It is very possible that the batteries are dead because they are so old. You may need to replace them. You will find the correct battery type at shaveroutlet.com. See link below. You will need 2
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To change batteries, remove three screws on back. The third screw is hard to see. To access it, you will need to remove the trimmer from the point that it pivots out from the shaver. Use a small flat screwdriver to gently pry the small plastic pegs from their corresponding sockets on the shaver body. Remove back cover. Inside, remove the metal clip that covers the batteries near the bottom of the shaver. Unsolder the batteries from the wires. Solder in the new batteries.
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Jul 14, 2011 | Remington Titanium SmartSystem R-9500...
bios password cracker
If you have forgot BIOS password then you have to reset CMOS jumper setting. Please follow the below steps: Open the Laptop back panel. Locate the CMOS battery, remove it & then with the help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battery & restart the computer. This will take care of the issue.
Thanks and regards,
Jitha
Nov 29, 2010 | Computers & Internet
How to replace keyboard for HP Pavilion DV2700?
Below is the link to the service manual and below that are the steps to the procedure. If want, open the manual and follow along with the procedures below, they are linked and cooincide with one another. The manual is free to copy, print and use.
http://h10032.www1.hp.com/ctg/Manual/c01295820.pdf
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the
computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery (see Battery on page 56).
Remove the keyboard:
1. Turn the computer upside down, with the front toward you.
2. Remove the three Phillips PM2.5×7.0 screws that secure the keyboard to the computer.
3. Turn the computer display-side up, with the front toward you.
4. Open the computer as far as possible.
5. Lift the rear edge of the keyboard (1) until it rests at an angle.
6. Release the keyboard (2) by sliding it back to disengage the tabs on the front edge of the keyboard
from the top cover.
76 Chapter 4 Removal and replacement procedures
7. Lift the rear edge of the keyboard (3) and swing it forward until it rests on the palm rest.
8. Release the zero insertion force (ZIF) connector (1) to which the keyboard cable is attached and
disconnect the keyboard cable (2) from the system board.
9. Remove the keyboard.
Reverse this procedure to install the keyboard.
Nov 05, 2009 | Computers & Internet
need to replace keyboard in HP Pavilion dv6626us Entertainment Notebook PC. thanks
Turn the computer off and close the computer lid.
Remove the battery and the AC power supply.
1st we need to remove the switch cover or keyboard bezel. This is plastic strip that runs above the keyboard.
Turn the computer upside down with the front panel towards you.
Remove the three Phillips screws that secure the switch cover to the computer.
Turn the computer display-side up with the front toward you.
Lift the rear edge of the switch cover and swing it forward until it rests on the keyboard.
Release the zero insertion force (ZIF) connector to which the LED board cable is connected and disconnect the cable from the LED board.
Remove the switch cover.
Now remove the panel directly above the battery compartment and remove the 2 keyboard screws there and another 2 screw in the battery compartment (they should me marked with icons of keyboards)
Turn the computer display-side up with the front panel towards you.
Lift the rear edge of the keyboard until it rests at an angle.
Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover.
Swing the keyboard forward until it rests on the palm rest.
Release the ZIF connector to which the keyboard cable is connected and disconnect the keyboard cable from the system board.
Just reverse the procedures to replace everything.
Good luck.
Sep 17, 2009 | HP Computers & Internet
203 people viewed this tip
David Payne
David Payne
