Tip & How-To about GE Spacemaker JVM1640SJ Microwave Oven
CHANGE BULB- GE MICROWAVE # JES1289SK01
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at cdpays@bellsouth.net.
Craig Pays
Kenner, La.
GE Spacemaker JVM1640SJ Microwave Oven Logo
how to change the lightbulb ze2160sf01
I found the following info: Hope it helps>
" I have included a schematic of the interior of the built in Monogram Advantium Microwave oven Model KSC1001. The interior halogen light burned out and had to be replaced. GE service wanted $138 to come out & service it. I tried to find instructions on how to take it apart and remove the bulb & replace it on the WEB but had no luck with the Monogram series so I went to the dealer in Denver, CO and talked with their technicians and they gave me the schematic and sold me 2 bulbs for $11.00. The halogen bulbs can be purchased at Home Depot for about the same price. They are 35 watt with wide metal connectors.
Mine has 2 side trim pieces so these have to be removed first. They have latches on the top that slide behind the sides of the microwave and attach at the top. After removing the 4 screws holding the trim pieces, slide these upwards and then pull out to the sides. 2.) pull the microwave out and set it on a solid surface. 3.) there are approximately 23 screws that need to come out before you can slide & life the cover off the microwave 4.) Then look inside towards the front and left side (looking from the rear forward) for a small metal cover. There are 2 screws that hold it down. 5). Unscrew the 2 screws and gently lift the metal container up. This is the housing for the light bulb. 6.) gently pull the old bulb out and using gloves or a cloth insert the new bulb.You need to keep oils from your fingers from getting on the bulbs. The oils make the bulbs burn out quicker 7.) Put the container back and screw in the 2 screws being careful not to dislodge any wiring 8.) Slide the cover back on and replace all the screws 9.) plug it into an outlet and open the door to make sure the light works 10.) replace the microwave, plug it in and put the trim pieces back on. 11.) go to a movie with the money you just saved "
Apr 07, 2014 | GE Monogram ZE2160SF Convection /...
cook top light stays on
Sounds like the bulbs shorted out the smart board, this happens sometimes when folks change the bulbs without up-plugging the oven.
Mar 30, 2014 | GE Microwave Ovens
need to replace lamp in GE Profile microwave model JE1590SH02
PMG!!! I called GE and was told that changing the light bulb is not a consumer replaceable part!!! Are you kidding me!! She told me I had to have a GE tech come out. Makes you want to buy GE appliacnces, right!
Mar 01, 2010 | GE Microwave Ovens
3,145 people viewed this tip
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
