Tip & How-To about Garden
Time to Winterize your lawn equipment.
Fall is here and now is the time to winterize your lawn equipment.
If you plan on using your equipment into the winter, then this is the time to stabilize and winterize your fuel. If you have any fuel left over from the summer, use it up now and get fresh fuel for the winter. Gasoline starts to "oxidize" in as little as 60 days. So take the older, stale fuel and use it up. Mix it with the good gas in your car if you have very much left over.
To winterize your fuel, start with fresh gasoline. Buy fresh gas from a station that sells alot of fuel, that way you are getting the freshest fuel possible. Add a stabilizer to the gasoline. I use "Sta-bil" brand, but you can use any brand of stabilizer that is local to you. Read the directions on the bottle and mix it with the gasoline. Fill the tank on your equipment and allow it to run for about 5 minutes. This will make sure the stabilized fuel is in all sections of the engine that have gasoline. Top off the tank and then store you equipment in a dry area. When spring comes around, you will be ready to use your equipment.
If you are still using your equipment, prep your fuel as above and make sure to top off the tank after each use. A full gas tank is less likely to absorb water from the humidity in the air.
This is also a good time to check the air filter.
We'll change the oil and sharpen the blade in the Spring.
Good Luck!
Garden Logo
How do I get the tv schedule for curling this fall and winter ????
Please next time use Google for this question. We can't find it here in Europe.
Oct 05, 2014 | Remington Instant Curls 1 1/4 Curling Iron
Is there going to be a dangerous winter this year?
It all depends where you live. But yeah winters are getting worse and worse. Global warming is not a myth
Sep 22, 2014 | HJC Winter Sports
have a Briggs and Stratten 4.0hp Lawnmower that starts but sputters. What can I do to get it running smooth...What is the Spark Plug GAP?
How old is the fuel? Drain old fuel, use premium fuel and change spark plug and maybe air filter. I start mine in the Spring using quickstart. It also starts and dies a few times and eventually keep running. Winterizing the machine in the Fall prevents most starting problems in the Spring. If this does not solve the problem, see a mechanic.
Jun 24, 2014 | Briggs & Stratton Briggs Stratton...
Which has the most advantage fall or spring tune-up of riding mower?
Spring, especially if you are doing it yourself and don't have to wait in line to get it into the local shop. If you do a lot of fall and winter tasks with your rider like haul wood or blow snow, then fall works, too. If not, then a fall tune up is wasted, as it will just sit there all winter gunking up (or not, if you have run it dry).
That's the news from Lake Woebegone:)
Farmerbear at FixYa.com
Sep 17, 2010 | Toro Lawn Mower With Toro Power Tools
B&D battery lawn mower - winter care
Hi, it depends on the age of the battery. if it's new no ploblem depending on the age you may have to give it a trickle charge in jan.
If this doesn’t work for you please write back. Thanks,
Nov 19, 2008 | Black & Decker 19" Electric Lawnhog...
168 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
