Tip & How-To about Computers & Internet
How to detect if your hard-drive is working or not/hard disk maintenance.
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
Good luck.
Computers & Internet Logo
I have a Samsung 3g 2tb harddisk and it makes strange noises. sometimes it doesnt work and a my pc freezed.
Here is what you need to know about hard drives.......
I hope this is helpful..........
Good luck.
Mar 07, 2011 | Samsung G3 Station Desktop External Drive...
wd my book flashing blue light. sill no power up
Good luck.
Jan 22, 2011 | Western Digital My Book Essential 1TB...
hard disk tiking when power up.
Good luck.
Jan 11, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
External Hard Drive Not Regonized
I can help you with this. Follow these instructions--> Start-->Control Panel-->Administrative Tools-->Computer Management, under the Storage section select "Disk management". Locate the external harddrive, and then change the drive letter.
Select the external drive. Right click, and select "Change drive letters and paths"-->Highlight the driveletter to change-->Click the "Change" button-->From the drop-down list choose an unused drive letter, and hit Ok.
The external drive should be recognized and accessible at this point. Let me know if you have any other questions.
Thank You, Raph30
Jan 28, 2009 | Western Digital 250GB MyBook External USB...
help!Help with external hard drive?
Your disk drive is a delicate instrument, it will react negatively if dropped on the floor.
However what you might try all be it rather radical in this age of micro fine technology is. take a deep breath and sit down. Take the disk drive in your left hand with the edge of the drive that struck the floor facing away, make a fist with your right hand and strike the opposite edge with with almost equal force.
The reason behind this is simply that when you dropped your drive on the floor the heads got jammed either into the disk spool or out side of it,
If you have to pay $300 for disk recovery you cannot be doing much worse than trying this before you have to.
Oct 20, 2008 | Maxtor OneTouch II external hard drive...
1,023 people viewed this tip
David Payne
David Payne
