Tip & How-To about Computers & Internet
How to Watch Video on iPad?
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
There is no other one than iPad can be more perfect for you to watch video on the go, the bigger iPad might be awkward for you to hold in some position, but 90-degree angle to use iPad from your lap is the position you'll ever found comfortable to watch video on iPad, bed or sofa will be also be ideal.
A pity that the NEW Apple iPad still can only play back H.264 MPEG4 (.mp4), mov, m4v Video files, so if you download flv video files from online video-sharing sites or have camera HD videos like AVCHD VIDEO(.M2TS, .MTS), even common Video files like AVI WMV MPEG that want to play Movie on iPad, you must need to Convert Video to iPad compatible formats.
Why We Need a Video to iPad Converter?
However, if we want to watch movies or listen music on ipad, we need use a video to ipad converter suite to help us.Video to iPad Converter Suite is all-in-one iPad Video Converter package for iPad, including two iPad tools: Video to iPad Converter & DVD to iPad Converter, to convert DVD movies and videos to iPad supported video format. With iPad Video Converter Suite, we can easily convert all our DVD movies and videos to iPad and enjoy it on-the-go. So with this single package we can convert both DVDs and video file media to iPad video and iPad movie formats.
Preparation: Download Video to iPad Converter and run the program, Click Video Converter button.
Step 1: Add Video to iPad Video Converter
Click "Open file" button to select and open the video file you wish to convert. Video to iPad Converter supports most of the popular video formats, so you can easily convert AVI to iPad, MKV to iPad, and even HD video formats like AVCHD M2TS MTS to iPad format.
Step 2: Select iPad preset from output format list
In the Output video section of the interface, choose the right preset for your iPad device in the "Profile" drop-down menu. There are many options when you're converting your videos for your iPad. Obviously, the better the quality, the larger the file size. Ultimately it's a personal decision everyone has to make on what's more important: space on your iPad or audio/video quality. Personally, I prefer to stick with the default profile because the good quality video and audio are given. You just have to pick and choose which profile you want to keep on your iPad. Play around and see which results you like best.
Step 3: Start Conversion
After all the necessary settings are ready, you can click "Convert" button to start convert video to iPad. As soon as the conversion is completed, you can click "Open" button to find out the generated files easily. And then sync them to you iPad, with iTunes.
Computers & Internet Logo
www digitalgadgets com
To put the iPad in the Smart Case, you have to push it into the main casing and it isn't exactly very easy to do. It's even more difficult to get off. This would be an acceptable trade-off if the case fit snuggly and perfectly -- but it doesn't. Although the iPad doesn't slide around inside the case, you can see a space between the iPad and the Smart Case. It also has a strange lip around the outside of the entire case, making the body larger than the Smart Cover. This not only makes the iPad larger without added functionality or protection, but also makes it a bit awkward to open the cover since you must get your fingernail underneath it in order to lift it. Well, that's not entirely true -- you could also just turn the iPad upside down.
Aug 13, 2014 | Digital Products Ultra Thin Bluetooth...
iPad Video Converter - Convert Video to iPad, put Video on iPad
I use Nidesoft Video Converter to convert my video format. http://www.nidesoft.com/video-converter.html
May 06, 2010 | Computers & Internet
184 people viewed this tip
David Payne
David Payne
