Tip & How-To about Computers & Internet
How to backup copies of all your disks
DVD and Compact disk disks became a part of our way of life; most of us have a significant assortment of motion pictures, audio CDs, photographs, video games, office paperwork as Ill as other disks. And it is really frequently that you simply require to make a backup of that disk, for backup functions or merely to produce a couple of copies of your Adding video clip for your close friends. You will find a lot of applications that may imitate your DVD motion pictures, but really number of those which may copy all of your disks, both Compact disc and DVD
Here I'll test a plan known as AVS DVD Copy, which claims copying any type of DVD and Compact disk disks. I'd prefer to check is it really can replicate any type of disk
Setup requires a number of seconds, the plan is created as a classic step-by-step wizard, and it appears slick and clear. Pick disk to copy, it is a DVD film now, and press "Next" button to go further. I've got two DVD movie drives on our test personal computer so the system asks do I want to imitate directly from drive to push? Yes I do! Press "Next" once again and it began to duplicate. By default it helps make a single imitate, but you are able to set quantity of copies as you like
Arrive again, now with a sound Compact disk. AVS DVD Copy does the task perfectly; I have received specifically exactly the same Compact disk, no top quality loss in any way! I did exactly the same with several of recreation CDs, CD with photographs, MP3 new music DVD, one more Digital video disc film, and one more Digital video disc film. All attempts Ire successfull, no hassles
Then I examined the way it operates having a solitary CD/DVD drive. First it copies from disk to computer, then asks to insert a blank disk and writes an imitate. It takes additional time, but the outcome can also be perfect
What I also observed is AVS DVD Copy does not decrease the good quality of DVD and DVD motion pictures and audio CDs, which is good. Actually, you get a correct duplicate, specifically the identical as authentic. AVS DVD Copy is seriously in a position to imitate any CDs and DVDs, and it does not matter what disk is in your push, you obtain a correct duplicate with AVS DVD Copy movie anyway. I successfully copied over 10 disks, both Compact disk and DVD, which contained video clip, MP3 audio, Compact disk audio tracks, pictures, paperwork, no cost computer software along with other stuff. It effectively recognizes various CDR/RW, DVD+/-R/RW disks and double-layer DVD movie videos
There's only a single function missed in AVS DVD Copy. Regrettably it can't encode 9 GB double-layer Digital video disc for the four.7Gb single layer, so individuals who're in search of this function will probably be frustrated. But in any case AVS DVD Copy is still a single in the best DVD Copy software program I ever seen.
Computers & Internet Logo
What's your problem?when i insert into compact disk the give the message please insert disk. please solved my problem..
put other working cds.if working,ur cd is damaged.if other cds are not working,ur cd drive is damaged.contact to ur service provider.
Jun 16, 2012 | Computers & Internet
i was wanting to know what kind of burned dvds it will play
it plays with no problem : CDR,CDRW,DVD+/-R,DVD+/-RW,Audio mpe 3,Compact Disk Audio(CDDA),Video Compact Disk(VCD),DVD Audio,Dolby digital track,JPEG pictures
Jan 09, 2011 | RCA RTD120 System
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
198 people viewed this tip
David Payne
David Payne
