Tip & How-To about Computers & Internet
How to recover sql 2000 sa password
Microsoft SQL Server 2000 is a full-featured relational database management system that offers a variety of administrative tools to ease the burdens of database development, maintenance and administration. It operates in one of two authentication modes: Windows Authentication Mode (the default) or Mixed Mode.
When you install the SQL Server 2000, you can log in the server with Windows Authentication and SQL Server Authentication if you select mixed mode authentication. If you select Windows Authentication, you cannot assign a sa password during installation. However, you should set the sa password after installation.
It is very easy for one to set sa password in SQL 2000. Just follow the below steps:
* 1. Expand a server group, and then expand a server.
* 2. Expand Security, and then click Logins.
* 3. In the details pane, right-click SA, and then click Properties.
* 4. In the Password box, type the new password.
The type of client connections determines the choice of security mode. If all of the incoming clients support trusted connections, you can use Windows Authentication Mode. If some clients do not support trusted connections, you can select Mixed Mode.
If you forget the sa password, you will need to use MS SQL Server Password Unlocker to reset sa password SQL 2000. MS SQL Server Password Unlocker is easy yet powerful SQL Server password reset software for you to reset SQL password, including reset SA password and other user passwords. It provides you an easy and safe way to reset SQL Server password for Microsoft SQL Server 2000/2005/2008 in a minute. No need for you to reinstall MS SQL Server on your PC. The file in master.mdf format is enough for you to recover sa password SQL 2000.
Steps to reset sql password 2000 for sa as follows:
* 1. Download and install MS SQL Server Password Unlocker.
* 2. Click the application icon to run it.
* 3. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
* 4. Select sa account, click Change password button to reset sa password.
* 5. Type a new password, and then click OK to finish your operation.
Note: This method to reset sa password in sql server 2000 is usually applied when you cannot login SQL Server 2000 by Windows Authentication wile you forget system administrator login password.
More information about sa password:
According to Microsoft, System administrator (sa) is a special login provided for backward compatibility. By default, it is assigned to the sysadmin fixed server role and cannot be changed. Although sa is a built-in administrator login, do not use it routinely. Instead, make system administrators members of the sysadmin fixed server role, and have them log on using their own logins. Use sa only when there is no other way to log in to an instance of Microsoft SQL Server.
Computers & Internet Logo
How to recover deleted Microsoft SQL server MDF files?
Recover and repair MDF files with simple and efficetive tool to repair and recover MDF files from corrupt and damaged SQL server, which tool support all king of SQL server version and Windows OS. Visit here: http://www.en.mdfrepair.net
Read blog post: http://exchangerecovery.hubpages.com/hub/How-to-perform-SQL-Database-Recovery Corrupt MDF File Repair Utility
Apr 17, 2014 | Computers & Internet
I forgot my sql server password, and i need to get the sql sa password back, how can i retrieve my sql sa password? its SQL server 2005. Any advice is ok, i dont want to reinstall the SQL server, Thanks in advance.
Lost or forgot your administrator/user password for Microsoft SQL Server?
If so, turn to help from AnyPasskey SQL Password Recovery, which is a professional program enables you reset administrator or user password for Microsoft SQL Server instantly regardless of the length, complexity, language and encoding of the password set before. As long as you got AnyPasskey SQL Password Recovery and master.mdf file, you could reset SA password on any authorized PC in minutes without the installation of Microsoft SQL Server. What's more, this featured-in tool supports all versions of Microsoft SQL Server and Microsoft SQL Server Express perfectly. 6_21_2012_1_55_07_am.jpg
Sep 15, 2010 | Computers & Internet
restoring files from the database
I suggest you use the Enterprise manager (gui tool to manage SQL).
Restoring a single table is not an option.
You can however restore a file or filegroup.
Make sure to backup before you start and NOT to restore database to its original name or original file location, to avoid acidents.
Normally you will have databases with only 2 files: the data at its Primary file group, and log file.
You may wish to create a new file group and move tables to the new group by recreating them there and exporting data from old table to new table. Then recreate indexes. This may prove to be complex as all tables and indexes have unique names and can't coexist with exact duplicate of them.
oh yea..... did I say backup?
well just in case backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup
but dont overwrite that backup
Feb 11, 2008 | Microsoft SQL Server 2000 Standard Edition...
195 people viewed this tip
David Payne
David Payne
