Tip & How-To about Computers & Internet
How to rectify the " and @ keys being swapped on Windows XP.
As luck would have it, this is quite a simple solution. If you click on start, then on the control panel icon, a window will come up. In this windows there is a link on the left which says "Switch to classic view" click on this (unless your already in classic view, it will say switch to category view), then double click on the 'regional settings' icon.
In the new window there will be lots of options.
On the first screen, select your country from both drop down boxes - one will be Satndards and Formats, the other location.
Then click the Languages tab at the top, followed by the details button.
On the settings tab of this new windows, click add then find your country in the list, click ok.
Highlight the new counrty by clicking on it, then click 'set as default'
Change the default country to yours in the drop down box at the top. You can delete the others if you wish.
Click OK at the bottom, you may get a warning telling you that the others cannot be deleted until you restart.
Click OK and you will be taken back to the regional settings window. Click the last tab - advanced, and select your country then click ok.
You should now find that the keys are now working correctly.
Computers & Internet Logo
volume icon missing
Which operating system ??
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer.
Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel.
Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel.
Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Dec 04, 2013 | Computers & Internet
How do I remove yahoo messenger from my computer?
If your computer operating system is windows vista or 7 click start button_settings--control panel-Programs and Features then you will see installed prrogrammes on your computer choose yahoo messanger from the list at the bottom and clik on it then you will see uninstall icon on the top click it and follow the simple step.
If it is windows xp go to start--- settings-control panel ----Add/remove programes and point to yahoo messenger and click remove good luck
Sep 16, 2011 | Yahoo Messenger
i am trying to connect my webcam with out the disc
Instructional steps
  1. Click the "Start" button, then click the "Control Panel" icon on the Start menu. This opens the Control Panel window.
  2. Click the "Switch to Classic View" link in the left-side navigation pane of the Control Panel window if the Control Panel is not already set to classic view. When the Control Panel is set to classic view, you will see the "System" icon in the right-side pane.
  3. Double-click the "System" icon in the Control Panel window. This opens the System Properties window. Click the "Hardware" tab; then click the "Device Manager" icon to open the Device Manager window.
  4. Click to expand "Sound, video and game controllers" in the list of device categories in the Device Manager window. Double-click the "Microsoft LifeCam" icon. This opens the Microsoft LifeCam Properties window.
  5. Click the "Driver" tab in the Microsoft LifeCam Properties window; then click the "Update Driver" button. This opens the Hardware Update Wizard. Follow the wizard prompts to install the Microsoft LifeCam VX 1000 driver and complete the process.
Oct 24, 2010 | Microsoft LifeCam VX-1000 Webcam
The device is not seen and cannot start/load
Here's How:
  1. Click on Start and then Control Panel.
  2. Click on the Performance and Maintenance link.
    Note: If you're viewing the Classic View of Control Panel, you won't see this link. Simple double-click on the System icon and proceed to Step 4.
  3. In the Performance and Maintenance window, click on the System icon near the bottom of the window.
  4. In the System Properties window, click on the Hardware tab.
  5. With the Hardware tab selected, click on the Device Manager button
Sep 17, 2010 | Computers & Internet
how do I change the date on the computer to DST?
Its Very simple. If you are running a Windows XP system, Click the start button - Settings - Control Panel - Double Click Date and time.
Change the Date and Time settings and Zone in the Three tabs which you have there. Isnt it Simple. If you are using a Windows Vista Machine please let me know so that i can help you with this. But both Methods are almost the same. Good Luck
Mar 14, 2010 | Dell Studio 1537 Laptop
1,001 people viewed this tip
David Payne
David Payne
