Tip & How-To about Televison & Video
Regarding reset codes
So many people i see are looking for this so called magic reset code and were is the reset button in 99% of cases there is no simple reset button when there is a internal fault a simple factory reset wont work its a dead compoinent it needs to be found and replaced with a new one. the simplest repair fault is a blown fuse yes in this case you can replace it as in some cases the fuse blows due to bad manufacturing but!! when the new fuse is installed turn the power on covering your eyes if it blows imediatly turn the mains power of and have the unit looked by a licenced tech
Televison & Video Logo
What does fault code 99 indicate?
What? 2days? Call the installer! or seller. Could be a gas supply safety problem!
Mar 24, 2012 | Maytag Neptune MDG6800 Gas Dryer
We cannot get the color to align. It appears like there is a blue or yellow background around words
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 02, 2011 | Hitachi 57F500 57" Rear Projection...
-AFTER TRYING SOMEONE TO UNLOCK MY HTC MAGIC BY MAKING TOO MAINY PATTERN ATTEMPTS...MY CELLPHONE LOCKED AND NOW ..ASK ME A USERNAME...AND PASSWORD...AND I CAN'T HAVE ACCESS TO MENU TO RESTORE IT
If you are talking about the PUK code ... STOP!!!
Review this article: http://en.wikipedia.org/wiki/Puk_code
You cannot guess the number ... trying 10 times permanently locks your SIM.
Call your service provider.
Jun 07, 2010 | HTC Magic Cell Phone
We recently installed a new replacement router WRT 160N V3 and something called Network Magic keeps interupting and trying to sell their service. We keep canceling them and then the router does not work and we have to revert to direct hookup. Is Network Magic the culpret. We cannot seem to get rid of them.
To clear out the problem if Network Magic has something to do with your connection.
1) Uninstall Network Magic from host computer.
2) Remove Ethernet connections to router.
3) Reset the router (press & hold reset button for at least 15 secs.)
4) Run Setup wizard on host computer and follow on screen instructions on connecting PC to router.
5) Setup wizard prompts on installing Network Magic, just ignore it.
6) if it automatically installs Network Magic just uninstall the program before you fully use your router.
Resetting router clears all settings made by Network Magic application made on the router.
Hope this helps.
Mar 13, 2010 | Linksys Wireless-G WRT54G Router
1,989 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
