If you're having trouble running older programs
originally developed for previous versions of Windows, you're not out
of luck. Luckily for consumers, Microsoft built Compatibility Mode into
XP. Compatibility Mode allows you to run a program using the shell of
the original program it was developed for. Today Chris shows you how to
access a program's Compatibility Mode in XP:
Find the executable or program shortcut icon you'd like to run.
Right-click the icon and select Properties.
Click the Compatibility tab and place a checkmark next to the text labeled "Run this program in compatibility mode."
Select the operating system that the program was originally intended to run on.
You
may need to fine-tune the three fields under "Display Settings" if an
older program requires 640x480 resolution or 256 colors.
Click Apply.
Try starting the program after making these changes. If it still
gives you trouble, try a different operating system. If the program was
written for Win95 and worked fine in Win98, there's nothing that says
it still won't work fine with Win98.
I get this ''Failed to open MCI device. Error Code: 348745'' message ever now and then. What can I...
(More)
I get this ''Failed to open MCI device. Error Code: 348745'' message ever now and then. What can I do to resolve this? Thanks, Ray
I want to set up my contacts to show journals. I tried going thru the setup of the journals thru...
(More)
I want to set up my contacts to show journals. I tried going thru the setup of the journals thru Journal Group Tab Listing...checked off the contacts that I wanted to show Journals...This did not work...Tried going into the Contacts thru ALL FIELDS once I opened the CONTACT...When I choose TOOLS...OPTIONS...JOURNAL OPTIONS it shows FOR THESE CONTACTS and it is still empty...What am I doing wrong? Also this is Microsoft Outlook 2007...
