Tip & How-To about HP Photosmart C6280 Printer
Steps to enable print directly to printer.
Click start.
Open control panel.
Open printers and faxes folder(in xp)
Right click on the printer icon and click properties.
Click on advanced tab and select print directly to printer option and click OK.
This will resolve most of the spooler issues.
HP Photosmart C6280 Printer Logo
I don't know how to disable "keep printed documents". I have an Artisan 800 series printer.
Hi Michelle,
Follow the steps below and you will be able to fix the issue.
Click on START button
Click on Control Panel ( or Settings for windows XP )
Click and open Printers and Faxes ( or Printer folder icon )
Highlight the Printer icon and Right click on it
Left Click on Printer properties
Click on Advanced TAB on top and look for "Keep Printed Documents"
If there is a Check mark, you can Uncheck it.
If there is no check mark on it, Check mark it.
Click Apply/OK and Close the window and try to print.
If this does not resolve the issue, Try the step below
1. Open Printers and Faxes.
2. Right mouse click on the Epson printer and left click Properties.
3. Click on the Advanced tab.
4. Click the Print Processor button.
5. Under Print Processor, select WinPrint.
6. Under Default Datatype, make sure RAW is selected. Click OK.
7. Back on the Advanced tab remove the check next to Keep Printed
Documents.
8. Click Apply and OK.
Regards,
Sean
Sep 14, 2012 | Epson Artisan 800 Series
printer prints a page then sends thru a blank page... prints page then blank page...
I posted this video a long time ago...hope it helps!
utube.png You-Tube video "WrxT2_T6JVA" placeholder (do not delete) utube.png
Good Luck!
Jan 02, 2010 | HP Photosmart C7280 Printer
Everything prints backwards...
Click on start and then click on control panel.
open the printers and faxes folder and right click your printer icon and select properties.under the ports tab remove the check that says bi-directional printing.Click on ok.
Once again click on the printer icon and select printing prefrences.Goto the advance tab and one of the options will say front to back/back to front the (only 2 options) select either and try to print and this should resolve your issue
Jun 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP C1480
Please perform the below steps to clear the queue and print from the computer.
Before performing the below steps try to make a copy from the all-in-one to check the hardware functionality.
Remove the USB cable from the computer.
Now click on start --> control panel --> printers and faxes --> right click on the HP C4100 printer icon and delete all the pending documents.
Now again click on start --> run --> type services.msc and press enter --> locate print spooler in services window and right click on the print spooler and click on refresh or stop the spooler service and then restart the spooler.
Now open the printers and faxes folder, right click on the printer icon --> properties --> advanced tab --> enable print directly to printer and click OK.
Now connect the USB cable back to the computer and then try to print from the notepad and check for the result.
May 29, 2008 | HP Photosmart C4180 All-In-One InkJet...
2,824 people viewed this tip
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
