Tip & How-To about Cell Phones
How to service aphone when dropped into water.....
How to service a phone
Hi, it works this way. First remove the battery so that the water will not make the phone dead completely.
You will need to service the phone by cleaning the phone.
First you will need a screw driver, to unscrew the phone, a methylated spirit, small brush and a dryer.
First, use the phone screw to unscrew the phone remove the board of the phone, take the brush and the methylated spirit, brush off the water of the board ( water is already dried up on the board), After brushing the phone board, use the dryer to dry off board.
When the board is dried up,you can replace the board back into the phone and screw back necessary screws.
After putting all the screws back.problem solved....
Cell Phones Logo
My fone dead put charger in does nothing dead dead dead
Nokia phones are notorious for slow response time when recharging from a completely dead battery.
Remove battery.
Make sure there is good contact between all of the contact points.
Replace battery.
plug in charger.
wait for at least 5 min.
If recharge symbol does not appear in window, then one of these things has occurred:
1. Phone has internal damage or water damage. no way to fix without nokia service.
2. Battery is dead. Try a new battery
3. Charger is bad. Try a new/different car charger or home charger.
These chargers are very inexpensive on Craigs List, try to solve it before throwing away the phone. Good luck,
A former Nokia employee.
Feb 16, 2011 | Nokia Cell Phones
my phone got really wet and it will turn on but it wont do anything but search for a signal
Hi, when a phone get wets, you will need to service the phone to clean up the wetness out of he phone.
First remove the battery so that the water will not will not make the phone dead completely.
Problem solved.
Hope that helped.
Oct 10, 2010 | Cell Phones
it fell in the toilet ,what to do?
Hi, you will have to service it to remove the water from the phone so that the phone can come on.
You have two options,the phone might come on and the phone might not come on,why because when a phone stays too long in the water it might not power up the phone unless the phone is flashed.
You can use this link to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Have a nice day.
Oct 01, 2010 | Samsung SGH-U600 Cellular Phone
Dead phone but keypad flashes
replace the LCD + flexcable on the phone.
Aug 02, 2007 | Motorola Mobility RAZR V3
V3 dead but keypad flashing
I had exactly the same problem. After unsucessfully looking for a solution on the net I removed the simm chip and set it aside. The next day, I put it on PC usb charge and left it overnight. The next day, I powered it up and it worked. I turned it off and replaced the simm and it is now working fine. Go figure...
Jul 29, 2007 | Motorola Mobility RAZR V3
114 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
