Tip & How-To about Computers & Internet
Troubleshooting Laptop Battery Problems
The first step in troubleshooting battery life or charging problems is to check your owner's manual or the manufacturer's website for how to interpret the status LEDs on the laptop. The LEDs on the laptop will change color or blink when there's a charging problem. The operating manual for the laptop or a search of the manufacturer's web site should tell you exactly what the LEDs are indicating.
If the LEDs indicate that the battery is being continually charged, yet the battery only lasts a short period of time, there's a good chance the battery is worn out or defective. Before giving up, perform one last test to determine if the operating system software is interfering with charging. Let the battery charge overnight with the AC adapter plugged in and the laptop turned off. If the battery won't take a charge with the laptop turned off, you can try powering on, entering CMOS Setup, and letting it sit and charge on the Setup screen for a few hours.
Even if the battery is healthy and the laptop charging system is working properly, the battery lifetime will be variable with how hard you work it. If you're in the habit of turning the screen brightness all the way up and choosing the highest performance battery management profile, the battery will run down much quicker than otherwise. You could change your battery management profile if needed. There are a number of predefined battery management profiles in the operating system, accessible through the little battery icon in the system tray.
The ambient room temperature and the temperature of the laptop (if you've left it in a hot car in the summer or a cold car in the winter) will affect the battery life as well.
Please Vote for this Tip if you found it helpful.
M. Omran
Computers & Internet Logo
His I've a victory xl mobility scooter and constantly red flashing on battery meter and don't charge battery's properly can u help cheers
Hi, at a guess I would say that your batteries possibly no longer hold a charge. If the scooter has been provided for you get the organisation who gave it to you to check it over, they should service it for you.
There is a link below for the website that provides an owners manual, this may help you troubleshoot the problem
If you need anything else please post another query.
Pride Mobility Victory XL 4 Owner Manual
http://www.manualslib.com/manual/718600/Pride-Mobility-Victory-Xl-4.html
Jul 16, 2015 | Health & Beauty
How to stop lights flashing on the control panel
Unplug the oven from the outlet or turn off the circuit breaker that controls power to the oven.
Wait about 5 or 10 minutes- so that any remaining stored capacitor voltage has been fully drained.
Restore power to the oven- if you get an alpha-numeric error/fault code or the lights on the oven's control panel blink, refer to your owner's manual for troubleshooting and/or interpreting the fault codes or flashing lights; or you can try contacting your local appliance repair shop for assistance in interpreting the fault errors or to schedule a repair service call.
Sometimes you can Google the error codes for info, help, and repair solutions...
You can also try the oven manufacturer's website to resolve your problem- they may have a troubleshooting/solutions link or phone number to get live tech support...hope this helps.
Mar 08, 2015 | Ovens
My nikon s203 battery will not charge. When the charger is plugged in, the light is red. When I put the battery in it, the light just flashes red really fast and will not charge. I have left it on overnight before, but it still will not charge. Is it a problem with my battery or my charger? I have not even had the camera for a year yet.
I just started having the same exact problem. I took it one step further and put the battery on a meter and it checks out at the rated 3.7 volts. Plus, the camera will not turn on. This problem is not covered in the "troubleshooting" guide of the owner's manual.
Mel.
Nov 30, 2010 | Nikon Coolpix S203 Digital Camera
My computer don't see my MP3 Insignia Player.Why and what can I do about it?
Ensure that the battery is charged and your player is turned on. If the player still is not recognized, try connecting with a new cable as cables can also become defective. As a troubleshooting step, see if a different computer will recognize your player. If another computer does, you may need to contact your computer's manufacturer for further assistance. Additional troubleshooting steps can be found in the owner's manual.
Mar 11, 2010 | Insignia NS-DV2G MP3 Player
how to change the battery
hi
its so simple...
  1. Step 1 Purchase a new battery. Refer to your laptop owner's manual to determine the type of battery you need. Compatible laptop batteries can be purchased from computer parts dealers, the laptop manufacturer, or an online auction.
  2. Step 2 Turn your laptop over and locate the battery compartment. Release the lock/latch and slide out the old battery. Refer to your owner's manual if necessary.
  3. Step 3 Install the new battery by first aligning its receptor pins with the pins in the battery compartment. Push down on the opposite end to snap the battery in place. Secure the lock/latch mechanism by sliding it back to the original position.
  4. Step 4 Plug your laptop into an electrical outlet to charge the new battery. It usually takes about 24 hours to complete the first charge. Subsequent charges will only take a few hours.
please rate me...
thank you
Sep 18, 2009 | HP Compaq Presario V2000 Notebook
3,272 people viewed this tip
David Payne
David Payne
