Tip & How-To about Garden
Riding Lawn Tractors with Hydrostatic Transmission Tip of the Year
Hello everyone! IF you have a riding mower or tractor with hydrostatic transmission you are going to love this insider's tip. Slightly overfill the transmission. Always keep the fluid level about 1/4 inch above the full line on the dipstick. Once you have done this you will instantly notice that the tractor has more speed in forward and reverse. You will also notice that it has more power when mowing up hill. Doing this solved several problems I was having with low power and also slow reverse. I had adjusted the linkage but it did not solve my problem, adding the additional transmission fluid did. Enjoy your more responsive tractor! Joe
Garden Logo
transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
Husqvarna 24hp VTwin Hydrostatic 48' cut riding lawn mower will not move either direction.
I would check the drive belt going to rear end if not that I would check fluid level in transmission.
Aug 04, 2013 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
How to fill hydrostatic transmission fluid on Poulan Pro
How do I check the transmission
How to Fill Hydrostatic Transmission in Lawn Tractor
http://husqvarna.custhelp.com/app/answers/detail/a_id/387/~/maintenance---what-type-of-oil-is-used-in-the-hydrostatic-transmissions%3F
Craftsman Hydrostatic Transmission Fluid Change
Jul 28, 2012 | Poulan Garden
The tractor will not go forward or backward it starts right up but will not engage
1) The drive belt between the engine and transmission has broken or jumped off a pulley.
OR
2) Your hydrostatic transmission is dead.
DO NOT STICK YOUR FINGERS UP INSIDE A RUNNING MOWER TO SEE IF THE DRIVE BELT IS MOVING.
Jul 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Oct 10, 2009 | Garden
295 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
