Tip & How-To about Computers & Internet
Avoid basic Windows viruses from infecting your PC via storage drives.
With the proliferation of mini storage devices is the chance of viruses to be transmitted from PC to PC via thumb drives or storage devices. Here is a simple way to avoid this.
Since most of the viruses launches when you open a storage drive, they usually take advantage of autorun.inf file. The key is to remove this file before opening your storage device.
To do that you need to do the ff:
1. Plug your thumb drive. Cancel any attempt from the OS to open it.
2. Press Alt then R or go to Start then Programs the Run and type cmd.
3. A window will pop up. Type the drive letter of your storage device.
e.g. >F:
[Note: do not type >]
4. The window will show this:
F:>
5. From there type:
attrib -r -a -s -h
6. Then type:
del autorun.inf
You can now safely open your drive without fearing of virus entering your PC.
Computers & Internet Logo
how to transfer LG cyon 2MP camera photos to computer
1. Connect your LG Cyon to your computer via it's USB cable.
2. Upon receiving a "USB Connected" notification atop the Notification bar, drag the bar down and select "USB Connected."
3. Now select the option corresponding to "Turn On USB Storage" or connect as "Mass Storage Device"
You should now see a new flash drive or storage device connected to your computer. Browse/Move/Copy/Delete files (including photos) as you would with any other flash drive or thumb stick.
Sep 25, 2011 | LG Cyon
every time its gets to 62% is says an error with (8002F997) ive tired the method by swiching the media sever to disable but that didnt work. what eles do i do
Error code "8002F997" means your PS3 is having issues updating your system software directly via internet. As a workaround you'll use external storage media, such as a USB thumb drive, to transfer the software to your PS3
1. Requirements
- A USB cable (not necessary if using a USB thumb drive)
- A PC with Internet access
- Storage media or a USB Mass Storage device such as a USB flash drive
2. Downloading and saving the software
- Plug in your USB drive to your computer, and create a folder on the storage media in which to save the update data. Create a folder named "PS3" on the storage media/USB device. Within the PS3 folder, create a folder named "UPDATE".
- Download the update data from
http://dus01.ps3.update.playstation.net/update/ps3/image/us/2011_0310_91ee193a2fa921a6fce780fc40236e3b/PS3UPDAT.PUP
and save it in the "UPDATE" folder.
Note:
Be sure to save the update data as noted below. If the data is not saved in the correct way, the PS3 will not recognize the update data. The folder name must be in all uppercase letters.
-> Location: Save in the "PS3" folder > "UPDATE" folder
-> File name: Save as file name "PS3UPDAT.PUP".
3. Updating the PS3 software
Note:
Do not turn off the PS3, or remove the USB drive, during the software update!
- Insert the USB drive/storage media into the PS3
- On your PS3, from Home Menu (second icon from the left) -> System Update ->Select [Update via Storage Media].
The system automatically searches for and finds the update data saved on the storage media or USB device.
http://us.playstation.com/support/systemupdates/ps3/pc_update/index.htm
Mar 24, 2011 | Sony Playstation 3 (PS3) Console
do not open any computer of my pen drive?
your pen drive has serios virus.
Any storage device ,if affected with virus user can not find and delete the virus .there is simply way just fallow ,but you need a fresh computer where can you see hidden system file, can open task manager. and can open group edit pollicy and can open registry.
Follow bellow the link and do step by step.
http://www.fixya.com/support/t7700913-usb_not_formating
http://www.fixya.com/support/t7665080-dell_inspiron_1501s_card
Hope this helps.
Shibuda,
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 18, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
hard drive upgrade . I cannot upgrade, I used ghost and created a partition, but I think the bios won't let me put in a 320gb drive any solutions?
1. Go to manufaturers website and search for a bios flash update.
2. utilize external storage for docs and the like via thumb drive or other device.
Aug 06, 2009 | Toshiba Satellite 2455-S305 Notebook
samsung sgh j700 phone shows up as mass storage device
check the pc connectivity settings on ur phone.
make sure that ur using the 2.0 port of ur computer
dont use front usb ports cpu. use rear ports. they are faster.
if still problem persists. try below
conect ur phone to usb. now without disturbing the connections switch off and then on the phone. now there may be chances.
samsung sofware could be corrupted due to virus on ur pc. remove all the viruses then freshly install suit
Dec 09, 2008 | Samsung J700 Cellular Phone
175 people viewed this tip
David Payne
David Payne
