Tip & How-To about Hampton Bay 36 In. San Marino in Brushed Nickel Fan
Fan speed switch wiring
If your are replacing the fan speed switch on the Hampton Bay San Marino mfg # 67353, this is the correct wiring pattern...L-white, 1-yellow, 2- blue, 3-black. I have been searching for this answer for 2 days. Thought I'd post for others with the same problem.
Hampton Bay 36 In. San Marino in Brushed Nickel Fan Logo
20 year old Hampton Bay fan requires new 3-speed pull chain fan switch replacement. I did not copy the wiring pattern for the L, 1, 2 and 3 positions. There are 3-wires: black, white and blue.
Typically AC wire protocol designated black = line voltage (means \'death\') and white is neutral (cold).
The blue one will be a switched line to the motor and a meter capable of checking continuity should allow you to determine the proper wiring.
Oct 14, 2014 | Hampton Bay Dryers
Wiring the replacement 3 speed switch (fan motor)
I called King of Fans and the rep that I spoke with gave me the correct wiring for the 3 speed switch:
L White
1 Yellow
2 Blue
3 Black
The problem is that after I wired it this way I am getting the same result (off on 3 settings and a motor hum on 1 setting). So, either the Westinghouse switch that I bought at Home Depot is not compatible or it is the capacitor. The saga continues.
Feb 18, 2009 | Hampton Bay 44 In. White Carousel II with...
Hampton Bay San Marino 36" Ceiling Fan
18 gauge is a little light... should use 14. Are you sure it is a hum, or is it possibly the fan resonating due to imbalance of the blades. Watch to see if the fan is oscillating when it runs. Also, does changing the speed affect the frequency of the hum. If this is the case, you have to balance the blades using metal shims.
Sep 20, 2008 | Hampton Bay 36 In. San Marino in Brushed...
2,062 people viewed this tip
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
