Tip & How-To about Computers & Internet
Windows XP HELP Windows key + R = Run menu cmd = Command Prompt iexplore + "web address" = Internet Explorer compmgmt.msc = Computer Management Windows key + E = Explorer ALT + Tab = Switch between windows ALT, Space, X = Maximize window CTRL + Shift + Esc = Task Manager Windows key + Break = System properties Windows key + F = Search Windows key + D = Hide/Display all windows CTRL + C = copy CTRL + X = cut CTRL + V = paste Keyboard Shortcuts [Alt] and [Esc] Switch between running applications [Alt] and letter Select menu item by underlined letter [Ctrl] and [Esc] Open Program Menu [Ctrl] and [F4] Close active document or group windows (does not work with some applications) [Alt] and [F4] Quit active application or close current window Ctrl] Lft., Rt. arrow Move cursor forward or back one word Ctrl] Up, Down arrow Move cursor forward or back one paragraph [F1] Open Help for active application Windows+M Minimize all open windows Shift+Windows+M Undo minimize all open windows Windows+F1 Open Windows Help Windows+Tab Cycle through the Taskbar buttons Windows+Break Open the System Properties dialog box explorer shortcuts END....... Display the bottom of the active window. HOME....... Display the top of the active window. Type the following commands in your Run Box (Windows Key + R) or Start Run devmgmt.msc = Device Manager msinfo32 = System Information cleanmgr = Disk Cleanup ntbackup = Backup or Restore Wizard (Windows Backup Utility) excel = Microsoft Excel (If Installed) msaccess = Microsoft Access (If Installed) powerpnt = Microsoft PowerPoint (If Installed) winword = Microsoft Word (If Installed) frontpg = Microsoft FrontPage (If Installed) notepad = Notepad wordpad = WordPad calc = Calculator mspaint = Microsoft Paint wmplayer = Windows Media Player control = Opens the Control Panel Internetbrowser type in u're adress "google", then press [Right CTRL] and [Enter] add www. and .com to word and go to it For Windows XP: Copy. CTRL+C Cut. CTRL+X Paste. CTRL+V Undo. CTRL+Z Delete. DELETE Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE Copy selected item. CTRL while dragging an item Rename selected item. F2 Move the insertion point to the beginning of the previous paragraph. CTRL+UP Select all. CTRL+A Search for a file or folder. F3 View properties for the selected item. ALT+ENTER Close the active item, or quit the active program. ALT+F4 Opens the shortcut menu for the active window. ALT+SPACEBAR Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4 Refresh the active window. F5 Cancel the current task. ESC
Computers & Internet Logo
list of commands for vista
CMD command list
http://ss64.com/nt/
Run command list
to open run Press and hold start button on keyboard and while holding start button press R just once, small run window will popup and you can type the commands inside the run box and press enter on keyboard or click ok to execute the command.
Administrative Tools
Administrative Tools = control admintools
Authorization Manager = azman.msc
Component Services = dcomcnfg
Certificate Manager = certmgr.msc
Direct X Troubleshooter = dxdiag
Display Languages = lpksetup
ODBC Data Source Administrator = odbcad32
File Signature Verification Tool = sigverif
Group Policy Editor = gpedit.msc
Add Hardware Wizard = hdwwiz.cpl
iSCSI Initiator = iscsicpl
Iexpress Wizard = iexpress
Local Security Settings = secpol.msc
Microsoft Support Diagnostic Tool = msdt
Microsoft Management Console = mmc
Print management = printmanagement.msc
Printer User Interface = printui
Problems Steps Recorder = psr
People Near Me = p2phost
Registry Editor = regedit or regedt32
Resoure Monitor = resmon
System Configuration Utility = msconfig
Resultant Set of Policy = rsop.msc
SQL Server Client Configuration = cliconfg
Task Manager = taskmgr
Trusted Platform Module = tpm.msc
TPM Security Hardware = TpmInit
Windows Remote Assistance = msra
Windows Share Folder Creation Wizard = shrpubw
Windows Standalong Update Manager = wusa
Windows System Security Tool = syskey
Windows Script Host Settings = wscript
Windows Version = winver
Windows Firewall with Advanced Security = wf.msc
Windows Memory Diagnostic = MdSched
Windows Malicious Removal Tool = mrt
Computer Management
Computer Management = compmgmt.msc or CompMgmtLauncher
Task Scheduler = control schedtasks
Event Viewer = eventvwr.msc
Shared Folders/MMC = fsmgmt.msc
Local Users and Groups = lusrmgr.msc
Performance Monitor = perfmon.msc
Device Manager = devmgmt.msc
Disk Management = diskmgmt.msc
Services = services.msc
Windows Management Infrastructure = wmimgmt.msc
Conrtol Panel
Control Panel = control
Action Center= wscui.cpl
Autoplay = control.exe /name Microsoft.autoplay
Backup and Restore = sdclt
Create a System Repair disc = recdisc
BDE Administrator = bdeadmin.cpl
Color Management = colorcpl
Credential Manager = control.exe /name
Microsoft.CredentialManager
Credential Manager Stored User Names and Passwords = credwiz
Date and Time Properties = timedate.cpl
Default Programs = control.exe /name Microsoft.DefaultPrograms
Set Program Access and Computer Defaults = control appwiz.cpl,,3 or ComputerDefaults
Devices and Printers = control printers
Devices and Printers Add a Device = DevicePairingWizard
Display = dpiscaling
Screen Resolution = desk.cpl
Display Color Calibration = dccw
Cleartype Text Tuner = cttune
Folders Options = control folders
Fonts = control fonts
Getting Started = GettingStarted
HomeGroup = control.exe /name Microsoft.HomeGroup
Indexing Options = control.exe /name Microsoft.IndexingOptions
Internet Properties = inetcpl.cpl
Keyboard = control keyboard
Location and Other Sensors = control.exe /name
Microsoft.LocationandOtherSensors
Location Notifications = LocationNotifications
Mouse = control mouse or main.cpl
Network and Sharing Center = control.exe /name Microsoft.NetworkandSharingCenter
Network Connections = control netconnections or ncpa.cpl
Notification Area Icons = control.exe /name Microsoft.NotificationAreaIcons
Parental Controls = control.exe /name Microsoft.ParentalControls
Performance Information = control.exe /name
Microsoft.PerformanceInformationandTools
Personalization = control desktop
Windows Color and Appearance = control color
Phone and Modem Options = telephon.cpl
Power Configuration = powercfg.cpl
Programs and Features = appwiz.cpl or control appwiz.cpl
Optional Features Manager = optionalfeatures or control appwiz.cpl,,2
Recovery = control.exe /name Microsoft.Recovery
Regional and Language = intl.cpl
RemoteApp = control.exe /name
Microsoft.RemoteAppandDesktopConnections
Sound = mmsys.cpl
Volume Mixer = sndvol
System Properties = sysdm.cpl or Windows logo key + Pause/Break
SP ComputerName Tab = SystemPropertiesComputerName
SP Hardware Tab = SystemPropertiesHardware
SP Advanced Tab = SystemPropertiesAdvanced
SP Performance = SystemPropertiesPerformance
SP Data Execution Prevention = SystemPropertiesDataExecutionPrevention
SP Protection Tab = SystemPropertiesProtection
SP Remote Tab = SystemPropertiesRemote
Windows Activation = slui
Windows Activation Phone Numbers = slui 4
Taskbar and Start Menu = control.exe /name
Microsoft.TaskbarandStartMenu
Troubleshooting = control.exe /name Microsoft.Troubleshooting
User Accounts = control.exe /name Microsoft.UserAccounts
User Account Control Settings = UserAccountControlSettings
User Accounts Windows 2000/domain version = netplwiz or control userpasswords2
Encryption File System = rekeywiz
Windows Anytime Upgrade = WindowsAnytimeUpgradeui
Windows Anytime Upgrade Results = WindowsAnytimeUpgradeResults
Windows CardSpace = control.exe /name Microsoft.cardspace
Windows Firewall = firewall.cpl
WindowsSideshow = control.exe /name Microsoft.WindowsSideshow
Windows Update App Manager = wuapp
Accessories
Calculator = calc
Command Prompt = cmd
Connect to a Network Projector = NetProj
Presentation Settings = PresentationSettings
Connect to a Projector = displayswitch or Windows logo key + P
Notepad = notepad
Microsoft Paint = mspaint.exe
Remote Desktop Connection = mstsc
Run = Windows logo key + R
Snipping Tool = snippingtool
Sound Recorder = soundrecorder
Sticky Note = StikyNot
Sync Center = mobsync
Windows Mobility Center (Only on Laptops) = mblctr or Windows logo key + X
Windows Explorer = explorer or Windows logo key + E
Wordpad = write
Ease of Access Center = utilman or Windows logo key + U
Magnifier = magnify
Narrator = Narrator
On Screen Keyboard = osk
Private Character Editor = eudcedit
Character Map = charmap
Ditilizer Calibration Tool = tabcal
Disk Cleanup Utility = cleanmgr
Defragment User Interface = dfrgui
Internet Explorer = iexplore
Rating System = ticrf
Internet Explorer (No Add-ons) = iexplore -extoff
Internet Explorer (No Home) = iexplore about:blank
Phone Dialer = dialer
Printer Migration = PrintBrmUi
System Information = msinfo32
System Restore = rstrui
Windows Easy Transfer = migwiz
Windows Media Player = wmplayer
Windows Media Player DVD Player = dvdplay
Windows Fax and Scan Cover Page Editor = fxscover
Windows Fax and Scan = wfs
Windows Image Acquisition = wiaacmgr
Windows PowerShell ISE = powershell_ise
Windows PowerShell = powershell
XPS Viewer = xpsrchvw
Open Documents folder = documents
Open Pictures folder = pictures
Open Music folder = music
Open Videos folder = videos
Open Downloads folder = downloads
Open Favorites folder = favorites
Open Recent folder = recent
Logs out of Windows = logoff
Locks User Account = Windows logo Key + L
Feb 07, 2014 | Computers & Internet
cant find my mac address
Assuming this is a Microsoft Windows system...
Click on Start
Then either Run (Windows XP)
Or just type into the dialogue box above the Start button (Windows 7)
Type in: CMD and press Enter
In the black window next to the >
Type in ipconfig /all and press Enter
In the output look for the Physical Address in the 12 character alpha-numeric format of:
xx-xx-xx-xx-xx-xx
This is the MAC address
Jun 02, 2011 | Computers & Internet
214 people viewed this tip
David Payne
David Payne
