Tip & How-To about Washing Machines
Appliance Repair Boise - Whirlpool Duet Dryer clicks but doesn't work.
If your Whirlpool Duet Dryer makes a clicking sound then nothing happens, you most likely have a blown thermal fuse or the control board is bad. It is possible the lid switch is bad but I haven't seen this yet.
Please be aware that sometimes a blown thermal fuse indicates a overheat condition most likely caused by a restricted or blocked vent. Get your vents cleaned every 3-4 years. Lint buildup wreaks havoc with dryers and keeps me in business.
Rich
Washing Machines Logo
dryer will not start when pushing start button it just clicks once
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Mar 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
THE POWER IS ON BUT WHEN I HIT START IT JUST CLICKS
You have a bad thermal fuse or a bad control board, likely. Check the thermal fuse first which is behine the bottom panel and behind the bottom duct assembly on blower housing.
Oct 11, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirpool duet. The lights on the front panel light up, but the dryer will not start. I just hear a click and then nothing ????
Remove bottom panel and check the thermal fuse just behind the ducting. If this is blown it's a inexpensive fix. If it's good you may have a bad control board. Remove control board an inspect the back side of it for burning.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Whirlpool Dryers
the sensing light comes on ,clicks, nothing happens
the sensing light comes on, I hear a click but nothing happens.
Dec 12, 2009 | Whirlpool GEW9200L Electric Dryer
680 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
