Tip & How-To about Refrigerators
Appliance Repair Boise - Maytag Refrigerator Lights Blinking, making Clicking sound
If your Maytag Refrigerator has the above symptoms, you may also see the dispensor ice door opening and closing, then your control board is likely bad. The control board is located on the back of refrigerator under a panel. Be sure to follow the instructions that come with the new mother board. There may be some re-programming that is necessary.
Rich
Refrigerators Logo
Ice dispenser door flap will not close completely. I'm sure something has sprung or broke inside the door. How do I get the face off to look at the mechanism that opens and closes the door?
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
refrigerator
it has a bad main control board call maytag they will most likely repair it in warranty for you
Dec 09, 2007 | Maytag MFD2560HES Bottom Freezer French...
dispensor display going haywire/ ice shoot valve opening by itself
It is not the circuit board in the door, it is the one in the rear of frig. I had the same problem, and replaced the front board with no results, replace the HV board and fixed the problem..
Sep 21, 2007 | Maytag MFI2568AE Side by Side French Door...
683 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
