Tip & How-To about Kitchen Ranges
Appliance Repair Meridian - Oven Bake Element Replacement
Oven Bake elements are relatively easy to replace but there are extra precautions that need to be taken. Do not touch, reposition, or remove element without unplugging the appliance. On some ranges there is always L2-120V that is live - not switched in but there constantly. If you happen to touch the element, if it's broken, you can become enlightened very quickly.
Anyway, on with the replacment. Remove two screws from the inside back wall to release back element. Carefully and patiently, work the back element towards you to expose the wire terminals. Disconnect wire terminals and install in reverse order.
Rich
Western Appliance Repair Meridian
Kitchen Ranges Logo
How do I replace my oven element
Hello.
Theoven is a particularly sturdy piece of kitchen equipment. It can handle dailyuse and still perform as needed. But of course, as with everything over time,the oven can eventually have some things go wrong with it. The first signs maybe subtle, like your cake not being cooked through, or you may notice the oventaking much longer than usual to come to temperature. When looking inside theoven as it is heating, you may notice tiny sparks along the bake element. Anyof these symptoms may mean it's time to replace the bake element.Instructionsand tools below Screwdriver, Newbake element, Electrical tape, Fiberglass tape, Flashlight1 The first step when it comes to working on yourelectric oven is to turn the breaker off at your home's service panel, orbreaker box. This is extremely important, because most electric ovens require220-volt electricity to operate, and that voltage won't only hit you hard, itcan kill you. Place a sign on your breaker panel stating that you are workingon the electrical. As an added precaution, unplug the oven from the walloutlet. Remove the drawer below the oven chamber to see if the plug isaccessible from there. Otherwise, you may have to pull out the oven a bit tounplug it.2 Be sure that the oven has not been used in a whileand that the elements are completely cool. Remove all of the racks from insidethe oven. If it makes it more comfortable, you can even remove the oven door byopening it and sliding it off of the "arms" that hold it in place.3 Locate the bake element. It resembles a metal tubethat's been bent into a square shape and it is located on the bottom of theoven's interior. It can be quite dark inside the oven, so grab your flashlightand shine it to the rear of the oven's interior to locate where the bakeelement is connected to the oven wall.4 There will be two screws holding the bake element inplace. Remove the two screws and place them somewhere where you will not losethem. Now, pull the bake element out of the oven wall. There will be wiresattached to each "leg" of the bake element. Note: There is usuallynot much wire to work with, so do not pull too hard. Once you have about 4 or 5inches of wire exposed, place a piece of black electrical tape over the wire atthe point where it enters the oven. This will help keep the wire from fallingback inside the hole.5 At the point where the wires are connected to thebake element, you should see a screw. Remove the screws and separate the wiresfrom the bake element. Keep the old element for reference when shopping for anew element that matches the old one exactly.6 Install the new element by connecting one wire toeach leg of the element with the screws, just as they were with the oldelement. Wrap a layer of white fiberglass tape around the terminals. Push thewires back through the holes in the rear of the oven until the bake element isback in position. Use the screws to secure the new element to the oven wall, asbefore.7 Replace the oven door if you removed itearlier. Plug in the oven, then turn the breaker back on. Turn on the oven andtest the new element. You may notice some smoke coming off of the element as itheats up for the first time. This is ok, as these are just oils burning off ofit. The smoke will stop in a few seconds.Thanks.
Sep 28, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag Range MER5875QAS Problem Need Help
it could be a fuse or some wireing it also could be the heat monitor in the back of the oven
Jan 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
I hit 350 and start on my range and sparks flew out of both sides and now the oven does not work. The stove works but not the oven. can you tell me how to fix this.
It sounds as if the bake element has failed. They cost around 8 to 20 dollars. You will need to unplug the stove first. (Shutting off the stove breaker is good to do before unplugging the stove as an added precaution). On the back of the stove there is a metal
cover with a couple of 1/4 inch hex screws. remove this cover and unplug the bake
element. Then remove the two hex screws inside the oven and slide out the bake element. The model number is located below the oven door behind the drawer to
purchase a replacement. Hope this helps.
Jul 13, 2011 | Frigidaire Kitchen Ranges
No heat from oven although fan and light are both working
hello gavin..... Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
This is an inexpensive part and relatively easy to replace. Call your local appliance store to obtain the part and the instructions on how to install it. Joe
Thanks for choosing Fixya!
Jan 05, 2011 | Belling XOU270 / XOU271 Electric Single...
kenmore oven not working
Hi, You need to unplug the stove, take the back panel off and check continuity on the bake element or after the back panel is removed, plug the oven back in, and turn oven to bake. You should get 240Volts to the two terminals on the bake element. If you have 240 Volts, the element is bad and needs replaced. I can ship you the new element.
Hope this helps
Vic
May 08, 2009 | Ovens
329 people viewed this tip
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
